Charging stops prematurely
SlimJim
935
933
For last two charging sessions at home, I got notification that the charging stopped before it reached my setting, 90%.
I unplugged and plugged it back and it would start charging for a minute and stop again.
It is supposed to charge to 267miles but it stops at 227 miles and sends me notification.
Has anyone experienced the similar situation?
SlimJim
935
933
It did it again today and it was trying to charge at 47A.
i unplugged it from the wall and plugged back it and now it us charging at 32A.
edit: and it stopped again at 235 miles.
next step is to go charge at supercharger to r/o defective charging cable at home.
stopcrazypp
11,133
6,269
There are 3 connection points on the Mobile Connector. One is the connection with the car, which you already tried. The other is the connection to the wall socket. The third is the connection for the given adapter to the Mobile Connector.
See page 7 and 8 on how to disconnect the adapter and reconnect it to make sure it is securely connected.
https://www.tesla.com/sites/default...bile_connector_owners_manual_32_amp_en_US.pdf
However, looking at your numbers, 47A shouldn't be possible on Mobile Connector, so something is either faulty or perhaps you are talking about using something else?
Reactions: rpiotro
MaskedRacerX
386
470
Vilano Beach, FL
Yeah, that’s the first thing that jumped out at me was when they said 47a and “unplugging it from the wall”.
@SlimJim
Can you clarify what EVSE (“charger”) you’re using, if it’s not the TMC, the specs - and also, what specification outlet it’s plugged into (amps/receptacle spec, ie, N14-50, N10-30)
SlimJim
935
933
I went to the supercharger and the car charged up to 90% just fine. That ruled out any faults on the car.
I drove a few miles and picked up a half case of IPA and drove back home. Then I plugged in the home Nema 14-50 on the car and it didn't want to charge at all. I unplugged the charging cable from the wall and took the cable apart with no tools. I was able to pull the adaptor off from the brick by bare hands. It looked very clean inside. I blew into it anyway and I put it back together.
Then I tried taking it apart again and I could not. Then I realized that the Nema 14-50 adaptor should not have come off from the charging brick with bare hands. I vaguely remembered that I should have to press in the hole with a screwdriver. I plugged in the car and it charged up just fine.
So it must have been the loose adaptor that came loose little by little since I bought the adaptor a little over a year ago.
Thanks for the help!
Reactions: MaskedRacerX
jjrandorin
Nov 28, 2018
11,514
13,422
Riverside Co. CA
Actually, no it doesnt. Supercharging completely bypasses the chargeports in the car, so it doesnt prove that those work at all. It just proves that your battery can take a DC charge directly (which is not what the mobile adapter does).
To "rule out the car" or "rule out the adapter" you will need to either use your adapter to charge another tesla, or take your car to another L2 charger and try it (supercharging doesnt count).
SlimJim
935
933
Hmm..
Then I wonder whether it has been fixed or what fixed it...
That's not what the manual says:
Ecoli
843
399
New Zealand
Have a look on plugshare app see if you can find a free L2 charger close by and try charging your car
Post some photos of what your actually using, you know the old saying...a picture is worth a thosand words
