Charging the Roadster with the Yellow 120V cable...
Discussion in 'Roadster 2008-2012' started by AEdennis, Oct 20, 2017.
Tags:
  1. AEdennis
    AEdennis Active Member
    It's been a while...
    [​IMG]IMG_20171020_091411 by Dennis Pascual, on Flickr
    Got to the office and realized I had a little bit of driving to do today and I didn't plug in last night. Have the CAN SR/JR in the car, but no convenient Destination or J1772 station nearby... So, out goes the Yellow cable.
    so far, added 6 miles in 83 minutes and charging 114V at 15A...
  2. bonnie
    bonnie I play a nice person on twitter.
    Columbia River Gorge
    My first five months here in the PNW, I charged my Roadster off the yellow cable. Painful, but doable. The Roadster made it through an epic winter plugged in, under an outdoor car cover. When I had bigger trips, I drove 20 m down the road to a destination charger. Then after that, I shared a TT30 between the Roadster and my X.
    Now I have 70amp service in the garage and thankfully, that's behind me.
  3. thefortunes
    thefortunes Member
    Wisconsin
    I "charge" at the office whenever the temp drops below 10degF (or so) with the yellow 120v cable.
    Not necessarily for the additional range, but to keep the battery nice and warm :)
  4. AEdennis
    Southern California... If it dips below 50F, it's already "freezing" for us...
    • Funny x 2
  5. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Impressive. ;)
    I can't remember the last time I used my yellow cable to charge. I always carry my CAN SR and J1772 but never carry the yellow cable. But then I always plug my Roadster in every night.
  6. AEdennis
    Ok. Final Tally. 30 miles in 6 hours, with a 10-15 minute interruption. (had to turn it off, adding load to circuit, didn;t want to share)
  7. Roadster
    Roadster JdeMO Powered
    SoCal
    @DeedWest, bring back any memories with #1213? ;) @AEdennis to the rescue with that SMC!
  8. ViviV
    ViviV Member
    Southern New Jersey
    I actually use the yellow charger on a regular basis in my garage because to maintain battery health I prefer to trickle charge only as much as I will need the following day. Overnight this is usually enough to replenish what I use in my daily commute. We were taught this trickle charge approach early on (circa 2012) with Model S and currently still charge at lowest rate that achieves needed charge level. The exception is for the Roadster during summer when I typically use the NEMA 14-50 (up to 40 amps) to cool down the battery when I arrive home each evening. For faster charging (up to 70 amps) I also have the option to charge with Tesla2 WC + Henry Sharp CAN Sr, but I have not needed this at home, I mostly use it at destination chargers. We have the Roadster HPWC, but have not installed it because while it would increase the charge rate from the outlet to 70 amps, it would essentially limit its use for Roadster which is not as flexible.
    Our garage is now well prepared for being ICE-free when Model 3 arrives with 4 charging options (including the 110V). The two Tesla 2 wall connectors have a master/slave relationship so they share a 100 amp line. If anyone cares to see the garage transformation we made earlier this year, below is a link to a Flickr photo album including some before and after pictures. The S lives in the S bay; for now, the Toyota with Model 3 plates lives in the Model 3 bay; and the Roadster lives in the racing flag bay. We even matched the carbon fiber of the Roadster on part of the flooring. The red Model S belongs to friends who came to visit. The 1992 jeep seen in before pics died (but was resuscitated in an amazing way by the person who bought it for $300--and then won 1st place in car show in Jeep class-pics at end of album). https://www.flickr.com/gp/[email protected]/j3B365
    • Like x 4
    • Informative x 2
  9. ecarfan
    San Mateo, CA
    I'm skeptical that the "trickle charge approach" extends battery life or reduces the degradation rate in a meaningful way compared to charging with an HPWC, or HPC in the case of the Roadster, But I could be wrong, and it probably doesn't hurt anything.
    Your EV garage is impressive! :)
  10. arcus
    arcus Active Member
    Denton, TX
    Beautiful work on the garage @ViviV.
  11. NigelM
    NigelM Recovering Member
    Northern Virginia
    That's the beauty of EVs: every electrical outlet is an emergency back-up for charging.
  12. ViviV
    ViviV Member
    Southern New Jersey
    @ecarfan I agree, doesn't hurt and one benefit in cold climates is the ability to time the completion of the charging for around the time the car will be driven in the morning so that the battery is warm. This is particularly useful for Model S because on very cold days Model S takes much longer to regain regen (can be 10-15 miles) than Roadster if the battery is cold. Therefore, depending on how much charge needs to be replaced, it can be useful to charge at low amps over night. In Model S we routinely use 5-10 amps on the wall connector. Easier, than scheduling a faster charge -- as long as one has the luxury of a dedicated charger and time.
  13. smorgasbord
    smorgasbord Active Member
    SF Bay Area
    I don't think that's the most optimal balance between charging and temperature. If anything, the Roaster Battery Life program (to which you-all should be contributing data, btw) shows that temperature is often correlated to battery life. There is no known correlation between charge rates and battery life on Roadster of which I'm aware - certainly not at 40amps or less. And I'd further be careful that anything "taught" (and from whom did this info come, btw?) for Model S battery life extension probably does not apply to the different battery chemistry and charging electronics in Roadster anyway. The only time low charging rates matter is when the battery is really really empty - If you drive Roadster's battery to a really low level, it'll tell you that it actually doesn't know how many miles of range are left. At this point when you try to charge, it may tell you to use the 110 cable to charge, particularly if you're trying to charge right after the drive.
    The best solution is to install OVMS in your Roadster and use whatever 220 volt charger is most convenient. You can then use the Cooldown function, which will automatically kick in if the battery is above a threshold you set, and then complete the charge at a current rate you set, starting or ending at the time you set. And, you can override charging from the app for those times when you do need the higher rate of charge, or charging sooner or later.
  14. ViviV
    ViviV Member
    Southern New Jersey
    @NigelM Indeed! The beauty of electric cars is that there is already an electric grid all over the country!
    Although, I should clarify that the 110V outlet that we use for the yellow cable had to be specially installed in the garage because all the existing outlets were GFI which the Roadster didn't like ("extension cord detected").
  15. ViviV
    ViviV Member
    Southern New Jersey
    @smorgasbord it was a Tesla service rep (in those days there were no service centers) who told us to trickle charge when possible. Data may have been anecdotal. I'll have to see if there is any supporting scientific evidence.
    Yup, I check the battery temp when I get home with OVMS app and use COOLDOWN command if the battery temp is greater than 88 F (31 C).
    @smorgasbord How does one go about contributing to the "Roaster Battery Life program?"
  16. smorgasbord
    SF Bay Area
    You can start here for any EV: Battery Survey « Plug In America
    And here's direct to the Roadster: Battery Survey « Plug In America
    You can set it up so that COOLDOWN is automatic - no app checking required. If you want instructions, let me know and I'll post them. Since ACC is setup via SMS, not the App, it's not as well known.[/user]
  17. ViviV
    ViviV Member
    Southern New Jersey
    @smorgasbord, yes, please. However, because I am using Hologram sim and my cell is Verizon I do not get any response SMS messages from the car, if that is needed.
    Could you also clarify the potential issue with the 110V charging -- is it that if you need to cool down the battery, the 110V does not supply enough power to do that and charge the battery so that there is the potential for heat-related degradation over time? Thanks!
  18. smorgasbord
    SF Bay Area
    Not quite. The potential issue with Hologram is that by default it does not have a phone number, so you can't send SMS directly to it. But, it will definitely reply to the registered phone via SMS no matter what service that phone uses.
    There are 2 ways to get SMS messages to a hologram SIM. The cheapest is to use hologram's dashboard web page (select your device then select the "via SMS" tab, and don't forget to enter your registered cell phone number (with the "+1" for US) in the "From" field. The easiest is to spend $1 more per month to get a phone number assigned to the phone.
    There are certainly more knowledgable people here with the details on this than me. I'd recommend reading this: Charging in High Temperature environments 13A vs 32A vs 70A: cost of air conditioning
  19. ViviV
    ViviV Member
    Southern New Jersey
    @smorgasbord I do pay for a phone number so I can send SMS from my phone rather than having to go to the dashboard and I have done extensive troubleshooting with Mark. The issue is that the SMS sent from Hologram comes from a fake country code +88 and Verizon doesn't accept the message even though they supposedly unblocked it for my account. There is a way around this that Mark said was less secure so I have not set it up mainly because I can get along with just the app and the COOLDOWN message. I'm sorry -- I wasn't asking for help on this -- I was just stating the bottom line which is that if your automated method requires a response from SMS, I can't get one (at least right now).
    I would love the instructions on how to automate the COOLDOWN.
    Thank you for the link to the thread -- I will read it.
  20. smorgasbord
    SF Bay Area
    I decided to the post the Cooldown and other ACC function instructions to the pre-existing OVMS Installation thread. You can find the post here: OVMS Installation
