This may be off topic, but then again, I think the topic of *how* to measure energy use in a good way is very topical to charging the roadster.
I've installed the
TED 5000 meter on my 14-50 outlet in my garage. Last night was my first night of charging. Here's the graph of the power draw (in blue) and voltage (in red). I was pulling 40A.
I've been waiting for a product like the 5000 to come out. Looks like it may not qualify as revenue grade accuracy or be accepted for performance based incentive reporting, but it otherwise looks like it has everything I was looking for in a monitoring package.
I didn't think it was out yet though! How'd you get your hands on it, and would you recommend it for monitoring the energy use of roadster charging?
I'd looked at a range of other meters from simple refurb utility meters to other logging units, but price and accuracy vary a lot and I hadn't found anything that was easy to read at a glance without a PC, logged data and had decent software for use with a pc, and didn't cost a bundle (if not directly, then indirectly due to panel and electrician costs). I'd pretty much given up on finding that combo, and decided to either go with a simple (but revenue grade) modular digital display non-logging meter for a couple hundred dollars, or see if the monitoring solutions for a solar install could add on another leg to monitor.
Unfortunately there's no Kill-A-Watt type 240V, 100A $20 plug in meter
(or link it if there is!)
Actually, speaking of charging the roadster and the Kill-A-Watt 120V meter, fyi it works well for measuring 12 Amp charging, but will incessantly beep, warning you of over-current use if you try to use it to measure 15A (with the MC120 and manual setting of the VDC current limit) or 16A (with the RFMC) charging, which is unfortunate. It's a great feature to have, but I wish it were rated for 20A, and the alarm was defeatable so I could use it in a 20 Amp rated circuit. Not sure of any other product in it's price range that does that though.
