If you are going to charge with 50A, make the breaker at 60A as well as the wiring. Otherwise you may loose to much voltage at the wire and the breaker may be get triggered as well after a few hours on hight load.
I'm not 100% sure what your errors are, but I had a similar problem (technically two different problems that are both similar to yours).
When you charge, do the LED's at the charge port turn red? Is the LED on the UMC red?
I haven't had any significant problems with my car, but I did have 2 problems with my UMC. My 1st UMC worked for a couple weeks, my 2nd UMC worked for almost 2 months, my current UMC is still working and approaching 3 months. TM was very good about it. They shipped a new UMC overnight no questions asked. As soon as I plugged it in and it worked, they asked that I ship the broken UMC back (they paid shipping). I wouldn't worry too much yet, wait and see what happens with the replacement UMC.
I'm wondering if the old UMC had problems like this. Is it a problem with the new design, or is it just dsm and I who are having problems with the UMC?
In most jurisdictions that is a requirement of the electrical code. The maximum permitted load is 80% of the rated load. Thus the 70A HPC requires a 90A circuit.
completely agree... that's how my 32A systems are wired and I can take 32A if I want it.dpeilow said:Over here in Europe kit is labelled for continuous load - so pulling say 32A from a 32A outlet on a 32A breaker is fine and indeed I have done it.
Probably not necessary, but shouldn't hurt. I guess the main thing is what charge level you need when you return (since it may have dropped some). Would be nice if you could check and set that remotely.How long do you have to be gone for it to be worth charging your Roadster in storage mode? I'm going on a long weekend trip (Wed-Sun kind of trip) at some point but wasn't sure if it was necessary to keep it in storage mode or not. Thanks.
It's stated that charging in performance mode will charge the battery up to 100% and with higher voltage than normal.
So here is my theory: If you charge in performance mode to 100% and then drive only in range mode, you should at least get the same mileage as when charged in range mode. Is it possible you could get a handfull more miles with performance charging?
