Tesla Perpetual Connector | Facebook
Well this makes our discussion about charging station locations obsolete...
Whatever you do, don't send that pic to that "searcher" fellow on the Tesla Motors forums...
I am sure AutoBlogNik will be all over that new perpetual charger.
My car did not adjust to British Summer Time (I'm based in the UK) so maybe it's a bug...Has this happened to anyone else?
I have had it screw up and start the charge early so that I have to top it off after I wake up in order to leave with a full charge.
I have not noticed any problems with the timer yet although I have not watched it that closely yet. You are saying that you had to top off in the morning because it started charging early, but wouldn't that be the case if it started changing late rather than early? Have you ever seen it start charging later than the time you set it to start? That would definately be a bigger problem...
Perhaps it is starting heating or cooling early in order to start the charge cycle as scheduled? Is this possible?
I had to top it off because it started early and therefore finished early, hours before I needed it, so it lost some charge. If it had started late, it would have still been charging when I checked it first thing in the morning.
How much charge are you losing by having the charge cycle finish a bit early? I'm not noticing any loss -- even though my charge cycle is finishing up in the middle of the night sometime, I still see 193 ideal miles every morning when I get in the car. Am I missing something?
I'm trying to get a hotel to install a charger so I can recharge while I'm there. What should I ask them to install if they'll do it?
...Or simply see if they could install a NEMA 14-50R outlet so I can use my mobile charger...
