Charging the Roadster
Discussion in 'Roadster 2008-2012' started by malcolm, Sep 14, 2008.
  1. slcasner
    slcasner Active Member
    Sunnyvale, CA
    I don't know how the yellow cables delivered with UK cars may differ from those for US cars. But for the US cars I can answer that the only active component as delivered was the GFCI built into the AC plug end. I replaced that with a standard plug because the GFCI was not reliable and was not really needed.
    For a US car, putting a 240V plug on the yellow cable does not work (I tested it). The car requires the J1772 pilot signal to be present when it senses 240V on the inputs so it knows how many amps it can draw. When it sees 110V (120V) it assumes 16A (the max continuous draw allowed for a 20A circuit under the US electrical code).
    But since the sockets are all 240V (or 230V) in the UK, the car's firmware would have to behave differently.
  2. hcsharp
    hcsharp Active Member
    Vermont
    How did you get a 120v cable in the UK? Tesla supplied a 230v cable in Europe/UK that would charge at 13A with no pilot signal just like the yellow 16A/120v cable that was supplied in North America. So, to answer your question the yellow NA cable will work on 230v if you meet some conditions. First, you would obviously have to replace the plug with a non-gfi Type G BS-1363 plug. You cannot use an adapter with the existing GFI plug. You would have to ensure that the pilot wire is connected to ground and not connected to the Neutral pin.
    You would also have to have a European spec Roadster. That's why I'm curious how you acquired the 120v yellow cable. It was not supplied with cars in the UK.
  3. hcsharp
    Vermont
    I see now from your avatar and signature that you do indeed have a EU right-hand drive Roadster. Still curious how you got your hands on a North American 120v cable.
    The cable does not have a "brick" or controller because the Roadster (like many EVs) will default to 13A if the pilot pin is grounded and connected to 230v (16A and 120v in North America).
    The yellow cable is rated for and capable of 230v if you make the modifications mentioned in my previous post.
  4. KJA2001
    KJA2001 Member
    UK
    My car is a UK built and specified car with a UK VIN but was exported to Japan, I think from new. Japan also uses 110V hence the yellow 110V cable. I do not actually have the car yet, it is on a ship in the Mediterranean but I will need to charge soon after it gets here so am planning ahead. I have an HC Sharp Can EU but am keen to have a backup.
    Thanks for the info above. I presume that the pilot wire is obvious and of smaller gauge than the others?
  5. KJA2001
    KJA2001 Member
    UK
    Ha, I had not looked at who I was replying to. One of YOUR CAN EUs I should have said.
  6. slcasner
    Sunnyvale, CA
    The pilot pin is present only inside the Roadster connector. The yellow cable carries only the two power wires and ground. I'm sure Henry is aware of that, so I'm not sure what he meant.
  7. hcsharp
    Vermont
    To get access to the pilot wire you would have to disassemble the Roadster connector. That's a lot of work. I was thinking you could test what the pilot pin is connected to with a DVM, but that's not necessary if you remove the GFI plug, which you have to do anyway. One of the power pins is Neutral in NA.
    Whether you can use the yellow cable at 230v depends on what software is installed in your Roadster. If it's the standard UK (Europe) firmware then you should be able to use the yellow cable with the modifications I mentioned. If you have North American firmware then you'll need a control box that will generate a pilot signal to charge at 230v 13A. I don't know if Japan destined Roadsters had firmware that was different from NA cars. I doubt it. My adapters work there the same as they do in NA. I know that Japan is a great place to buy a Roadster!
  8. KJA2001
    KJA2001 Member
    UK
    Thanks Henry. Yes, I have looked at Japan for some time as the steering wheels are (mostly) on the correct side for UK. Were there routine firmware updates after June 2011 when my car was born? Do we have version numbers for NA / UK / EU / Asia firmwares and can I get the car's current firmware version from the touch screen? I will test the pilot wire connection when it arrives. Is there a schematic showing the pin identification?
  9. drewski
    drewski Supporting Member
    SF Bay Area
    you can get FW versions in the Diagnostic menus.
    in NA, the last 2.0/2.5 FW is 4.7.2
    not sure if differed WW - there are flags and other options within the FW (accessible by Service Center, not end user) for HW differences like the Single Motor / Dual Fan upgrade they did so regional differences could possibly be done in there two.
  10. KJA2001
    KJA2001 Member
    UK
    I now have my car and have tested the yellow cable. The pilot pin is not connected to anything. I know that the cable was used in Japan on their standard 100V supply and charged at 15A.
    Any tips on taking apart the roadster connector so I can try to connect the pilot pin to ground? Or will it work without it being grounded? Am I likely to damage the car by trying?
  11. slcasner
    Sunnyvale, CA
    I have detailed instructions for opening the Roadster connector that I could send to you, but before doing that you should try the cable as-is. You will not damage the Roadster by connecting 230V to the two power wires. I have tested that with my US-spec Roadster and our local 240V supply. The Roadster declined to charge with that setup because the US-spec cars only allow 120V charging without the active pilot signal.
    I'm not positive whether the pilot pin should be open or grounded for the inactive mode.
  12. hcsharp
    Vermont
    I agree with slcasner that you won't hurt anything to try the cable as-is on 120v (or 240v), especially since the pilot pin is open. You may have some region-specific firmware that allows it to charge at low amps without the pilot wire connected to anything.
    Taking the OEM connector apart is not easy, especially the first time. It's worth giving the cable a try as-is before starting a disassembly project.
  13. KJA2001
    KJA2001 Member
    UK
    Thanks both. I fitted a UK 13A plug and tried it, nothing happened.
    Are you able to post a link to the instructions or email them to me?
  14. slcasner
    Sunnyvale, CA
    PM me your email address and I will send the instructions I have, written by Martin Eberhard.
    I wonder if you could test grounding the pilot pin using a very fine wire (like wire-wrap wire) inserted into the female pin sockets of the connector. It would need to loop all the way down in the space between the plastic surrounding the pins because there is a mating piece of plastic in the connector on the car side.
  15. KJA2001
    KJA2001 Member
    UK
    Yes. I had thought of trying something like that as a test before taking it all apart. I presume that very little current carrying capacity is required?
    PM on it's way.
  16. slcasner
    Sunnyvale, CA
    Correct.
  17. hcsharp
    Vermont
    Less than 6ma.
  18. KJA2001
    KJA2001 Member
    UK
    Ok, I joined the pilot and ground in the Roadster plug with a single fine copper strand in an inverted W shape. The car still does nothing when connected to 240V.
    It has firmware 4.6.8 HW Pkg 40. I believe that there is a later firmware update so I will get that done here in the UK and see if it makes any difference. If not, I presume that this cable has a value?
  19. imdbui
    imdbui Member
    PNW
  20. Bunnak
    Bunnak Member
    Orange County, CA, USA
    Now and then you'll see it listed for sale here on TMC.
