Charging through a doorway from another room
Discussion in 'Model 3: Battery & Charging' started by fr100, Aug 18, 2018.
  1. fr100
    fr100 Member
    Northern CA
    I need to charge a few times a month at a location where the only 240V outlet is in the laundry room just inside of the garage. I'd like to keep the door closed to keep out critters, and also hot/cold air. The only thing I can think of is a small pet door at waist level with a sliding cover that can be put in place when not in use. Anyone have a better idea? Putting an outlet in the garage is not an option.
  2. Ludalicious
    Ludalicious Member
    Vancouver
    I would look at taking the threshold on the bottom of the door right off and see if the cable fits under it. Then just install a larger sweep to fill the extra gap.
    I can park my car outside my garage door and close the door on the cable without even knowing it was under the door. The larger sweeps hide allot.
  3. MXWing
    MXWing Well-Known Member
    Rat can fit through a hole the size of a quarter.
    @fr100
    Without building a new outlet, you can't extend the one currently in the laundry room? Would be way cleaner and make life easier.
  4. Thomas Edison
    Thomas Edison Active Member
    Portland-ish
    Is this a permanent long term solution you are looking for? Can you take a picture of the wall inside the door on the hinge side? How far is it from the outlet to the door frame?
  5. peachfuzz0
    peachfuzz0 Member
    Montreal, Canada
    You could buy a cable hatch that are used for RVs. They're round doors made for 16-50 plugs to be passed through.
  6. RedSafari
    RedSafari Member
    Toronto
    I have a similar setup for occasional use and I decided not to modify the door as it would affect its fire rating. I just keep the door cracked open and the garage roll-up door closed, and we don’t leave the house while the car is plugged in.
  7. Glamisduner
    Glamisduner Active Member
    Escondido, CA
    Why can't you put an outlet in the garage?
    Seems to me, that would be the only reasonable solution. Or drill a hole in the wall and put the cable through it?
    Or Drill a hole in the floor and put the cable through that?
  8. Venomized
    Venomized Member
    San Jose, CA
  9. davewill
    davewill Member
    San Diego, CA, US
    No easy solution. Garage doors require closers and weatherstripping to keep car fumes out of the house. Also, there fire rating issues. Any permanent modification to the door is probably a bad idea. Even the RV passthrough mentioned should only be installed to the outside, not into the house.
  10. davewill
    davewill Member
    San Diego, CA, US
    Cords through walls and floors are definitely code violations.
  11. AudubonB
    AudubonB Mild-mannered Moderator Lord Vetinari*
    Good manners count.
    Whether it’s through the pet door or any other, whenever the dogs charge through, they’re told “SLOW!!!!!”
    • Funny x 2
  12. Ludalicious
    Ludalicious Member
    Vancouver
    If it's only an electric vehicle then you dont need to worry about fumes. As long as no flammable material is stored in the garage it shouldn't need to be fire rated. IE. Lawnmower, Gas ect. Not saying it isn't by code. But if it's only an electric vehicle stored in the garage the rules really are different. I know some might argue that the battery could catch fire, and there are known cases of this. But let's not forget we have batteries on almost everything else in the house.
  13. thecloud
    thecloud As rhythm raced inside, the ship came alive
    Sunnyvale, CA
    My first thought on reading the headline was, "uh oh, someone's had an 'unintended acceleration' event and there will be photos of a Model 3 sitting in their living room with splintered wood around the doorway they plowed through." Fortunately the reality is very different, and I suspect any dogs in the vicinity are very well behaved.
    Words have power, people! I charge you all to remember that. ;)
  14. davewill
    davewill Member
    San Diego, CA, US
    Actually, the RULES are not different. Maybe they should be, although building codes can't assume that you'll only ever have an electric car. Also, it sounds like the OP is a visitor at this site, so there's probably other cars in there usually.
