Charging times / range question ?
Discussion in 'Charging Standards and Infrastructure' started by SSD420, Sep 18, 2016.
  1. SSD420
    SSD420 Member
    ON, Canada
  2. SSD420
    SSD420 Member
    ON, Canada
    Oops didn't post my question..
    Anyways, I understand that the 64km/h is approximately how much range I'll get per hour, but what about the +136? Is this additional range per hour? Per entire charge? What does the + represent?
    I poorly judged my evening and I'm in the middle of nowhere using a local charger outside of a fire station. (Thanks to the Plugshare App saving my ass!
  3. ibdb
    ibdb Any excuse for a road trip
    Puyallup, WA
    Isn't that how much range that's been added since you started charging?
  4. SSD420
    SSD420 Member
    ON, Canada
    I have no idea. Hence why I'm asking. But it can't be.. It saw the number drop briefly, then go up again.. But maybe you're right? I've always wondered
  5. SSD420
    SSD420 Member
    ON, Canada
    I'm pretty sure I had more than 118km of range left when I plugged in.. But I don't remember. I already cleared my notifications on my iPhone, so I can't confirm,..
  6. ibdb
    Puyallup, WA
    How long have you been charging? If it's been nearly 2 hours, that would be about right.
  7. SSD420
    SSD420 Member
    ON, Canada
    Actually you're probably right. I've been here over 2 hours already :(
  8. SSD420
    SSD420 Member
    ON, Canada
    If I know that I will probably use my 90% to get home (and run a few errands along the way), am I better charging to 95% than 100%? Or does it not matter once I go above 90%?
  9. ibdb
    Puyallup, WA
    Not sure if you're still there -- At a Supercharger, the closer you get to 100%, the rate of charge will taper off, so it doesn't usually make sense to wait. At a "slow" charger, like you're on, that taper would not be nearly as noticeable. Charge what you need to complete your journey, assuming you have no other charging options before arriving at your destination.
  10. SSD420
    SSD420 Member
    ON, Canada
    I'm still here...
  11. SSD420
    SSD420 Member
    ON, Canada
    I want to do a few more things here before heading home. I'm up to 327km now. My typical 90% is 375km (down from when I took delivery at 379km). I set my charge limit at 100%, so that I don't notice the slow down, but will probably not stay until 100%. Am I really tricking my car by doing this? Or am I ruining my battery? I will probably charge to what I know to be my 90%
  12. SSD420
    SSD420 Member
    ON, Canada
    Still here... Almost done.
    The world needs more superchargers!!!
  13. ibdb
    Puyallup, WA
    You're not ruining your battery by charging to 100% on those times that you need the additional range -- unless you're doing that on as a regular practice. Whether you set the limit to 90% or 100%, the rate of charge won't vary as you near a full charge. The car knows the actual size of your battery. The charge limit is just an "artificial" cap on it.
  14. SSD420
    SSD420 Member
    ON, Canada
    I charge to 100% if I know I'll be doing semi long drive one way and know that I need to make the round trip the same day....
  15. Ciaopec
    Ciaopec Reservations at Restaurant at Universe end.
    End of the Universe
    It is the amount of range you have added since charge began.
  16. SSD420
    SSD420 Member
    ON, Canada
    Yes @ibdb indicated that early this morning when I needed to know.
  17. ibdb
    Puyallup, WA
    There are lots of other posts here from people more technically qualified to talk about what charging to 100% all the time would mean, but that doesn't sound like what you're doing. You charge to 100% if you're going to need that little extra bit of range to make it to your destination. To me, if I'm not going to have access to some other way to charge during a long drive, it's a no-brainer. Either you charge to 100% and make it through your entire trip, or you charge to less than 100% and don't make it -- I'll take arriving at my destination every time.
    If there's some way to top-off your battery mid-trip, that might be better for the long term lifespan of your battery than continually needing to charge to 100%, but if charging isn't available, you do what you need to do. You'll get more comfortable with understanding the range of your car and your range anxiety will decrease over time. You might be able to trade driving at a slightly slower speed at increased efficiency than a higher speed that uses more juice. As weather changes, and things start to cool off, your driving and charging behavior might need to adjust again. If you're regularly driving to new destinations (or until you're familiar with driving to those destinations in an electric vehicle), you can use evtripplanner.com to get an idea of expected power usage at different conditions and speeds. It's also a good idea to get familiar with the Energy App and the Consumption Chart to get a better representation of the range you can expect based on your actual driving patterns and planned navigation routes.
    Plug-Share is definitely a great tool to help you out when you need to find options for charging outside the Supercharger network.
  18. dgpcolorado
    dgpcolorado high altitude member
    The Western Slope, Colorado
    Be aware that by charging to 100% you will have no regen braking until you run the charge level down some. For those of us who deal with steep hills it is a safety consideration. Otherwise, just expect that you are going to have to use the brake pedal to slow, rather then regen (if you are used to single pedal driving). The first time you back off the accelerator, and the car doesn't slow at all, can be a bit disconcerting.
    Just saying...
  19. SSD420
    SSD420 Member
    ON, Canada
    I experienced this once on my first long trip. It really threw me off until I understand why.
  20. SSD420
    SSD420 Member
    ON, Canada
    My range anxiety has definitely dropped down since having my MX for 2 ½ months, but reading stories on here about being ICE'd or plugs not working and now travelling to places whereas I can't find any places to charge on charge point has me exceptionally concerned about winter. Every Tesla owner that I've met has warned me that I will lose approximately 20% of my range.
    I do a lot of driving. In fact I found since getting my MX, I've driven even more. I'm at the 2 ½ month mark and I'm almost at 13,000 km. (Thank goodness for the 8 year, unlimited warranty on the battery!).
