Charging with the MC120
TEG
Teslafanatic
Aug 20, 2006
21,717
8,682
Tesla's least expensive charging option is the MC120.
This plugs into a 120V NEMA5-15 or NEMA5-20 socket.
They say that it normally charges about 4 miles per hour connected (12amps) resulting in about 48 hours to get a full charge.
If you change the VDS to pull 16 amps (when using NEMA5-20) then you get about 5 miles for every hour connected resulting in about 37 hours to get a full charge.
SByer
'08 #383
Oct 23, 2007
1,068
3
Cupertino, CA
Some of us have replaced the GFCI with this plug. The rubber strain relief from the GFCI will fit in this plug with only a little extra effort when screwing the clam shell back together. This plug is also a little more "share the receptical" friendly.
