race cars are long gone Kind of a been there done that type of thing. The planes are much cheaper to play with (I do all my own work) and they hold their value.
Lots'o pics here
Cars
The car I was running at the end-
99Shell Atlanta 1 - YouTube
__________________________________________________________________________________________________________
Logger firmware updating
The logger uses a drag and drop firmware update.
The current firmware is C0000X8 where X denotes TPS Threshold for logging
A is 75%
B is 50%
C is 25%
These are arbitrary and easily changed if needed.
The update files are 126 kb in size and are named UPDATE_C0000X8.EBL
Follow these steps to update the logger-
1)
drag and drop or copy the desired .EBL file onto the logger. It will appear as another file on the “disk” when copied over.
2)
Cycle power to perform the update. Upon re-powering, the LED will go Red while the logger checks the file integrity then Blue while the actual update occurs. If there is a file integrity error (does not pass RipeMD160 checksum) you will get a two blinking Blue error code. The Blue light extinguishes when the update is done. This occurs within a few seconds.
There are two ways to cycle power and they must be handled differently.
The first is to simply disconnect and reconnect the USB plug. The update will occur and the FAT file system will be erased BUT the data file storage section will NOT be erased. If you use USB power cycling to do the update, you will need to erase the log data file so that the logger will erase the flash storage space when it is plugged into the car (like you would normally do while using the logger).
The second way to cycle power is to disconnect the USB after copying the .EBL update file onto the logger and plugging it into the car. When powered, you will see the Red then Blue update LED sequence. When the Blue light goes out, the logger will perform its normal boot sequence as if you had erased the log data file. It will do the RGB post LED sequence followed by steady Red while it erases the flash data storage area. This is how I normally do it as the firmware update part is fast enough that there is no imposition.
Dropbox - UPDATE_C0000A8.EBL
Dropbox - UPDATE_C0000B8.EBL
Dropbox - UPDATE_C0000C8.EBL
Lots'o pics here
Cars
A is 75%
B is 50%
C is 25%
1)
2)
