Chassis' VIN
Discussion in 'Model X' started by sladotron, Jan 4, 2017.
Tags:
  1. sladotron
    sladotron Member
    Russia
    Does anyone know where the chassis' VIN number is stamped on Model X?
    I know that Roadster's chassis VIN is stamped behind the right wheel well.
    Need the vin location for inspection in Europe.
    Thanks.
  2. 3s-a-charm
    3s-a-charm Active Member
    Calgary, Canada
    Can you not see it from the windshield? If you look in from outside.
    Also on the sticker located on the door frame of the drivers door.
  3. PedanticOne
    PedanticOne MyTesla Refresh Champion
    Bay Area, CA
    The Owners' Manual tells all.
  4. sladotron
    sladotron Member
    Russia
    A picture is worth a thousand words :)
    Where is the sill panel?
    Is it the metal piece that you step on as you get into the car?
    If so, how do you remove it? It seems quite sturdy.
  5. PedanticOne
    Bay Area, CA
    #5 PedanticOne, Jan 5, 2017
    Do you not have the owner's manual?
  6. sladotron
    sladotron Member
    Russia
    #6 sladotron, Jan 5, 2017
    Yeah, I have the owner's manual.
    Page 151 says to remove the maintenance panel in the Frunk and chassis' VIN should be under that panel, however I couldn't find a stamp anywhere.
  7. PedanticOne
    Bay Area, CA
    I posted pic above.
  8. sladotron
    sladotron Member
    Russia
    Thanks, that helps.
