Hkbruin
You should be fine, I had some pieces that had that, but its typically because of the paper thats creased/folded, not the PPF film. The film you can fold on itself and it won't leave a crease ( just make sure you don't fold the adhesive side onto the adhesive side accidentally!)
Once you peel peel off the film, the paper will be creased and the film is ok.
Check the paper backing side before you remove the film; you should see the crease on the back of the paper.
