Check your AC
Discussion in 'Model S' started by norm, Feb 11, 2017.
Tags:
  1. norm
    norm Vendor
    RIO VERDE, AZ
    If you have not needed to use your AC, Check it to see if it will blow cold air. I am located in Scottsdale , AZ and Thursday while doing errands, temp was 84 deg and I needed the air, ??? No matter what I did only warm air.
    I was near Scottsdale SC and stopped in to to ask about the settings, thinking maybe the settings were not correct. They checked it and pulled the car logs. Determination was that there was not communication with the chiller. They were kind enough to give me a loaner and would let me know later that day what was needed. They contacted me late that afternoon and said they need to replace the chiller and would have car ready Friday late am.
    When I picked up the car, I inquired about the exact problem. Get his, one of the latest firmware releases is incompatible with some of the chillers and need to be replaced. I was a little shocked, as our car S 75D was delivered in Dec 2016.
    There was an other owner with same issue at the SC when I was there. So If you live in a cold region and have not needed the AC, you may want to check before warm weather arrives.
    I want to give the Scottsdale, SC a big thanks for stepping up and resolving this issue so quickly. I only stopped in because I was driving by their location and expected to make an appointment if service was required
    • Informative x 6
  2. Bluechip
    Bluechip Member
    Cypress, Texas
    It happened to my wife on her way home yesterday (Model S - delivered in mid-Dec). When she got home we rebooted the main screen and it still didn't work. She called service and was told the first thing to do was to reboot. She said she had already tried that and it didn't work. Service told her that they had seen this issue before and rebooting usually works but it takes a few hours, so check it in the morning. They said to call back if that didn't work as they had the parts necessary to fix and would provide a loaner. This morning it was working fine.
  3. mustafazr
    mustafazr Member
    LA
    Happened to me, SC replaced chiller, same issue - logs should car can't communicate with chiller occasionally. Didn't know it was FW specific.
  4. kdday
    kdday Member
    AZ
    Thanks. I'm in AZ too. I'll test today.
  5. apacheguy
    apacheguy S Sig #255
    So Cal
    Is this primarily affecting late 2016 builds?
  6. Lu Ann
    Lu Ann Member
    Phoenix, AZ
    I just got my car back last night for the same issue. It was also at the Scottsdale SC. Well, on the bright side, at least it happened in February instead of the summer time.
  7. Lobstakilla
    Lobstakilla Member
    Scottsdale
    I am in Scottsdale too and got a mid December delivery, same exact problem. Odd part is, it is very intermittent. Some days it's as cold as can be and some days it just blows warm humid air. I hope they get this figured out soon as I have a 20 month old son who is in the car all the time.
  8. Petra
    Petra Member
    Palmdale, CA USA
    When you say chiller, I'm assuming you're talking about the A/C compressor?
  9. HX_Guy
    HX_Guy Member
    Phoenix, AZ
    Chalk me up as another one that has had AC issues...live in Peoria and purchased an inventory car in late December.
    For me, it almost seemed like it was a settings issue. If you put the AC to "ON" but turn off "AUTO", then the AC turn off too? AC as in cold, because the fan still works.
  10. demundus
    demundus Active Member
    Oceanside, CA
    interesting this is on 2016s... there was an older issue with a sensor tesla will straight up remove to fix this problem in older cars.
  11. jaswill
    jaswill Member
    texas
    Im in Texas and just had car delivered and on the way home same thing happened. Being fixed now.
  12. dhanson865
    dhanson865 Active Member
    Knoxville, Tennessee
    I wonder too, Chiller - Wikipedia says a typical chiller is 15 to 2000 tons (ie not suitable for use in a car, not that it actually weighs that).
    I'm assuming someone that is used to using that term is misapplying it here or that based on the description the "chiller" is related to the battery pack coolant loop. Either way it isn't the term I expected to see in this thread.
  13. croman
    croman Active Member
    Chicago, IL
    WTF Tesla. Luckily I'm in Chicago and don't need AC for a while...
  14. Petra
    Petra Member
    Palmdale, CA USA
    Yeah, I'm thinking the OP meant A/C compressor... though, the car does have what looks to be a plate type heat exchanger that ties the HVAC refrigeration loop into the battery/electronics coolant loop. It's possible that whatever diverts the refrigerant to said heat exchanger could be the problem as well (since diverting the refrigerant causes the cabin A/C to not work worth a damn).
  15. Bluechip
    Bluechip Member
    Cypress, Texas
    Chiller was the term the service technician used when talking to my wife about it too. I just assumed that the Tesla has a different system than traditional cars.
  16. David29
    David29 Supporting Member
    DEDHAM, MA
    Doesn't it seem odd that Tesla would replace hardware rather than fix the software if indeed it is an incompatibility?
    If the A/C worked before the software change, why isn't that a bug fix? Heck of a lot cheaper and easier than hardware replacement.
    Seems like there might be more to it...
  17. Bluechip
    Bluechip Member
    Cypress, Texas
  18. kdday
    kdday Member
    AZ
    Just tested mine in my Dec 16 AP2 car and AC is cold.
  19. Lu Ann
    Lu Ann Member
    Phoenix, AZ
    I have a 2013 model so it's not exclusive to 2016 models. The following is exactly what they did with my car:
    Part Quantity
    COMPRESSOR, A/C ELECTRIC (6007380-
    00-C)
    Parts Replaced or Added
    Corrections: DCDC Converter - 1st Generation
    Replaced DC/DC converter. Verified proper operation after replacement.
    Part Quantity
    DCDC CONVERTER ASSEMBLY (6009170-
    00-J)
    Corrections: Install Acoustic Cover And Bracket
    Installed acoustic cover and bracket for a/c compressor. Verified proper operation after
    replacement.
    Part Quantity
    MDL S, COMPRESSOR NVH COVER
    (1028988-00-A)
    BRKT AC COMP TO AC BRKT (1006079-00-
    D)
    Corrections: Receiver Dryer and Desiccant
    After replacement of a/c compressor, replaced a/c dryer and desiccant. Verified proper
    Part Quantity
    Desiccant Bag - Subcool Condenser, 37g
    (1007717-00-A)
    Cap - Receiver and Drier (1007718-00-A) 1
    • Informative x 2
  20. norm
    norm Vendor
    RIO VERDE, AZ
    Chiller is how Tesla SC referred to the part ???
