JPP
Follow up-data point. I like America's Tire (Discount Tire elsewhere). I got tires about 2 years ago, and at that time the guys did use 4 floor jacks, properly positioned. A few days ago I was due for new tires, and went back to my local store. The tech had me pull into a bay with one of their low profile floor mounted 'platform' lifts (they don't seem to use the post type lifts with the swing out adjustable arms). This lift has 2 wide side rails with rubber pads, with ramps at the front and rear ends to drive up and over. Once I drove in (guided by the tire tech), I got out of the car and had a careful look to see if this could be used with hockey pucks (I keep 4 in each S). Turns out that there are 2 problems:
Clearance between the rubber side rail on this kind of lift and the lift points on the S would not allow a puck to slide under (...yes, Jack Mode enabled).
The overall length of the rubber padded side rails on the lift was not long enough to span the distance between the front and rear jack points.
I showed and explained this to the service tech, who clearly had beed lifting Teslas with his lift system (and applying pressure along the side of the pack). I then pulled out my hockey pucks, put them on the metal plates of his 4 floor jacks, and showed him how to identify the jack points (look for the 3 large holes, center up on the middle one). He jacked the car up, did the tires, and we had no problems. All good. No worries.
