After having a discussion about the Bolt on reddit, I did a bit more research on GM's Gamma II platform and realized that the Bolt is very straight forward BEV conversion of the Chevy Trax/Buick Encore/Opel Makka. I knew it was based on the Gamma G2SC platform, but I didn't realize just how close it was going to be to it siblings. The recent videos and spy shots reinforce that this is a much more straight forward conversion.
Chevrolet Trax - Wikipedia, the free encyclopedia
Opel Mokka - Wikipedia, the free encyclopedia
Chevy Trax:
Buick Encore:
Bolt:
It's not surprising that GM has gotten the basics of the Bolt up and running as the platform is already well sorted as there are multiple shipping vehicles including other CUVs based on the Gamma 2.
If you take the base price of a Buick Encore ($25,000), delete the ICE portions, add in the BEV portions sans battery (motor, inverter, charger, high voltage wiring, battery controller, better computers with better telematics) for about even pricing and then add in $13,500 for a 45 kWh battery, then the price is basically what they announced ($37,500). I think it is reasonable to assume that the initial production runs of this vehicle are not intended have positive gross margin, but rather grab 4 ZEV credits.
I actually went to my local GM dealer and checked out a Buick Encore, just to personally get a feel for the dimensions. The Encore's wheelbase is 100.6 inches. By comparison, the BMW 328i has a 110.6" wheelbase. The track in both is almost identical at just over 60 inches. The Model S wheelbase is 116". There is headroom, so raising the floor a bit and lowering the outside skirt should provide some room for a floor mounted battery, but will probably be lumpy like the Leaf's battery (higher under the seats). But still there isn't all that much room for the battery. I have a hard time seeing that this vehicle will have a 50-55 kWh battery given the dimensions.
Given the actual sizing of the vehicle, the expected NMC chemistry and costs, and the aggressive price point, I have a hard time believing this vehicle will have 200 miles of EPA range as I think this vehicle will have closer to a 40-45 kWh usable battery capacity necessary to achieve 200+ miles of UDDS range. At 1.9C, a 45 kWh battery can charge at 85 kW, which lines up with 200 amp CCS (400 volts x 200 amps = 80 kW). That might be why we haven't seen a push for a revised CCS spec for level 3 DC charging > 200 amps with a vehicle that is expected to arrive sooner rather than later.
