The DC chargers I mostly have used don't display detailed current and voltage data and neither does the Bolt EV. The 100A chargers from BTC do, so someday soon I will do a 15-100% charge on one of those and record the details. Basically, I think it starts off charging at the peak current (typically 100 or 125A today) and holds that until it reaches the low 50% SOC area. The graph shows the drop at around 52% but my experience was around 54% when I watched closely one day.Thanks, that helps a bit. It seems it peaks in power at 50% SOC, although it isn't that clear if that is the crossover point for peak current vs voltage.
What is with the jagged power cut after 50% SOC? Is that an artifact of the data gathering or is that actually how the BMS/charger is cutting current?
The jagged power cuts are actually what the Bolt EV BMS tells the charger to do. It seems rather primitive and I would have assumed a smoother rampdown in charging current but it is what it is.
