From a battery efficiency perspective,
60 KWH = 1 Bolt like EV = 6 10kwh PHEV = 40 Hybrids
If you don't believe battery capacity is a limitation, see DiCaprio's documentary. Elon himself says we need 100 GF.
But whole 100 mil cars sold today could be hybridized with just 150-250 Gwh of batteries a year. No need to wait 100 years till we reach 100 GF capacity.
Lol. Exactly the John Petersen argument. Let me just straight tell you that you can't make six 10 kWh PHEV packs from the materials/cost of one 60kWh pack, nor can you make 40 Hybrid packs from the same 60kWh pack.
That assumption completely ignores the power requirements of PHEVs/hybrids, and the cycling requirements. The PHEVs and hybrids need more power optimized chemistries (which tend to be worse in terms of kWh for the same material), and proportionally shallower cycles so that the batteries can last through their warranty period (since they get proportionally less miles per cycle).
A good proxy to material is weight (parentheses is relative scale to Bolt as reference).
Bolt 60 kWh (1): 960 lbs (1)
Volt 18.4 kWh (3.26): 405 lbs (2.37)
Malibu Hybrid Li-ion 1.5 kWh (40): 95 lbs (10.1)
Prius Prime 8.8 kWh (6.82): 265 lbs (3.62)
Prius Hybrid Nimh 1 kWh (60): 89 lbs (10.8)
Prius Hybrid Li-ion 0.75 kWh (80): 54 lbs (17.8)
Drive Unit and Battery at the Heart of Chevrolet Bolt EV
Chevrolet Pressroom - United States - Volt
2016 Chevrolet Malibu Hybrid Tech Dive: Voltec 2.0 - Motor Trend
https://www.toyota.com/priusprime/ebrochure
Why Toyota offers 2 battery choices in next Prius
Toyota Uses Smaller Li-ion, NiMH Batteries for New Prius (1)
As you can see, for a Bolt equivalent, you can build roughly 2-4 PHEVs, roughly 10-20 hybrids (or 0 depending on how you count Nimh, as that does not conflict with lithium-ion demand).
The problem isn't that we can't build the batteries fast enough, it's that there is not enough demand. Do you seriously think the PHEVs and hybrids are supply limited right now due to batteries? I don't think the sales data reflects that.
Some of the initially launched EVs might have short term supply issues (the Bolt seems to be past that now though), but that is a different matter (short term).
