My bad.... that was brucet999.
Sorry about that.... too many 9's I guess.
No prob, even I did a double take at first when I saw brucet999's posts. Lol
"Wait, I don't remember posting that! .......oh, nm, that's not me."
How would you shave more weight off a car?
By making the bowtie logos smaller.
What about using more Carbon Fiber?Like they did with the Z/28?
That was mostly to increase cooling during track use than weight.
Chevrolet replaces 'bowtie' with 'flowtie' in Z28
Or was that honestly the best thing you could think of? Don't worry, if aren't an engineer or you don't race, you probably have no idea what goes inside cars.
If, indeed, that cord can be used at 240V, then 12A would be twice the wattage of a 12A 120V. If it works at 240, then that suggests the the same onboard charger/rectifier must be used on the North America and Euro versions of the car. Makes sense, actually.
Engineering is seldom a simple choice such as price, or everything you see would look like it came from Harbor Freight. Making heavy stuff that is weak is cheap. Making light stuff that is strong is not.
The seats are thinner in the back to increase usable interior volume and they are lighter. There is no guarantee they are cheaper than cheap power seats. Some of the most expensive seats you can buy are manual or fixed (not adjustable at all).
My understanding is that the initial Roadster used something along these lines for it's charging architecture.Integrate the AC charger into the traction motor's drive inverter software. Allows for AC charging at up to whatever 2 phases of the motor inverter regen input is rated for rather than a pitiful 6.6kW. Also saves a set of liquid cooling connections, valves, a circulator pump, bracketry.
Ultimately they moved away from this design in later versions of the Roadster (and the Model S/X platforms), ostensibly for technical reasons as opposed to IP licensing issues with AC Propulsion.
Thanks for the impressions. How tall are you and did you find head and leg room to be sufficient? Were there any unusually tall people with you who had impressions in that area. Do you think you could seat five adults as GM claims?
It seems to me the power seats omission is purely a cost consideration, and it will be interesting to see what is left out of of the Model 3 to hold cost to the promised level. My suspicion is that very few will buy one at the base level, so it will be eliminated as an option over time (like the 40 kWh and 60 kWh model S).
I'd suggest you get a wall charger such as HCS40 from Clipper Creek but get one with a Nema 14-50 plug on it (not hardwired), and also install a Nema 14-50 socket on your garage wall. Why a 14-50? Well because there is a good chance you'll own a Tesla soon enough and the Tesla uses just that, a Nema 14-50.If you want 240V charging, you have to order a hard-wired (40A breaker) wall-mounted 32A charger for $800; capable of a respectable 25 rated miles per charging hour.
I stopped by a dealer to see the Bolt today.
It looks smaller in real life than in pictures.
I noticed that it comes with only a 120V charging cable; not surprising, but what did surprise me was that the cable itself is only 18ga wire. That seems much too skimpy for sustained loads. I won't run my hand-held circular saw or Sawmill on anything less than 12V extension cords if I can help it.
IIRC, it uses the same Clipper Creek EVSE as the 2016+ Volt. You could not use 18ga wire in an EVSE. That's about 6 amps, and the charger goes to 12.
If you feed it 240vac, it charges at 240v x 12a which is about 10 mph.
40a L2 = $499 for 14-50 long reach portable Juice Box.
Stamped right on the cord of the supplied 120V charging cable, "18AWG"
You can, if it is very, very short.Must be magic. How can you pass 12 amps through 18ga multi-filament?
