Chicago electrician recommendations
Discussion in 'Midwest/Great Lakes' started by Argelius, Aug 11, 2013.
  1. Argelius
    Argelius Member
    Palm Springs, CA
    I'm on the verge of pulling the trigger and getting an S.
    The one unknown for me that remains is how I'll get 240V outlet in my garage.
    I live in a 115 year old house (in Andersonville) with a detached garage, accessed via the alley. The garage has on existing 110 outlet (for the door opener). There is a very old single fuse box in the garage (with a screw fuse). The electric meter is on the back of the house, with the fuse box in the basement.
    The electricity to the garage must be underground. Digging up the back yard, which isn't really an option given the extensive hardscape and decking. So I guess a line would need to be run overhead to the garage.
    Anyway, I'm clueless about all things electrical, so have no idea how this might be accomplished and at what cost. Maybe it's not that big of a deal, but would like to know this part of the puzzle before I take the $100,000 plunge....
    Can anyone recommend an electrician in Chicago that might be up for this challenge?
    Thanks!
  2. bonnie
    bonnie Oil is for sissies.
    Columbia River Gorge
    Mod note: thread moved to regional forum.
  3. scottf200
    scottf200 Active Member
    Chicagoland ModelX S603
  4. FlasherZ
    Just off-the-cuff, it's not going to be an inexpensive proposition. A new feeder will have to be run from the home to the garage, probably the best bet is directly from the meter to a new panel in the garage. Off the cuff, without looking, I'm guessing a few thousand ($3,000 would be my wholly unqualified WAG) to do the feeder run from the base of the meter using AL to a new panel in the garage, a circuit for your door opener, and a circuit for the charging. That doesn't include permitting fees. It'll be more if you have to upgrade your service (new meter pan, etc.)
    Underground really isn't that hard to do... directional boring makes it pretty easy to work around stuff like that.
    One of the Chicagoland folks can probably point you at a good electrician. Good luck!
  5. axehomeyg
    axehomeyg New Member
    Chicago, Illinois, United States
    I used Matt @ http://melectricianservices.com for my installation (and other electrical work). He has experience with HPWC installations. He also re-routed power to my detached garage when I lived on the northside (I also had no clue how I was going to accomplish what I needed in that scenario, since the old wiring was underground and fried after a thunderstorm). Good luck, you won't regret taking the plunge!
  6. kcveins
    kcveins delivery 2/7
    Chicagoland
    I used Kapital Electric, as did many other in this forum - talk to Don Butler. Mr. Electric is Tesla's 'recommended' company and their quote was only a touch higher.
  7. sp4rk
    sp4rk Banned
    Schaumburg, IL
  8. Argelius
    Argelius Member
    Palm Springs, CA
    Thanks for your thoughts on this.
    Maybe I'll get a really long extension cord and have the 240 outlet installed in the basement..... ;-)
  9. Ravarju
    Ravarju Member
    Chicago
    If in the Chicagoland area and looking to install a Nema 14-50, I would highly recommend RJK Electrical Solutions. I worked with Joe Ambrosini and couldn't have been happier. His service was reasonably priced, fast, professional and on time. He clearly knows his stuff and is familiar with the needs of a Tesla Charging station.
    Joe Ambrosini
    [email protected]
