I'm really curious to see how folks have installed car seats that have the top tether on the Model X seats given there's no hole in the headrest to snake it through. We have a couple of Diono's and are wondering how people have made this work.
Ignore what the manual says. Maybe it shows that because of some legal need but over the top doesn't work. Any movement the straps will wiggle off the top of the seat and then fall off the edge of the seat and it's unsafe.
If you have the straps go around the side of the seat down to the hook you can get great tension and because the lower rear hook is behind the top of the car seat it holds the top securely and it will not allow the top of the car seat to move.
Totally agree with this – what I hate though is that in my experience, the forward facing car seat isn't exactly centered on the seat, as it's pulled toward the outer edge, the same side the tether is slinger over.
Not sure in that case then. Ours for the top strap is basically a loop which goes on both sides so the tension is evenly distributed on the sides (I should have mentioned that) so maybe it doesn't work for all situations.
I have a Britax Marathon and have the same problem, it wiggles off the top. Question about having it go on the sides though, doesn't that stop side seat-located airbag from deploying?
