Assuming a similar (gentle) style of driving and accelerating, would using Chill add range over Standard? Has anyone ever tabulated that?
Yes, I usually get better mileage on the highway for long trips in chill mode.Assuming a similar (gentle) style of driving and accelerating, would using Chill add range over Standard? Has anyone ever tabulated that?
And if it changes throttle response, it changes efficiency. The fact that you are arguing that exact point, tells me you haven't put much thought into it.No. It doesn't make a difference cause it doesn't change efficiency. All it changes is the throttle response and max power.
Throttle response is how much power you get from stepping on the peddle. If I normally get 50% power when I step 1" in to the peddle, on chill, I only get 25% at 1 inch. If I leave it in normal mode and I want 25% power, I just step a half inch in to the peddle.And if it changes throttle response, it changes efficiency. The fact that you are arguing that exact point, tells me you haven't put much thought into it.
The throttle position moves hundreds of times per second. It's not just when you think in your head it is moving. It is never static. When the throttle reacts 50% faster, there are many more spikes and draws than exist with a slower and smoother reaction. This little graph here is just a random one from the internet not associated with throttle response, but it displays the same thing. The spikes would be driving in regular mode, the median would be driving in chill mode. Those spikes can last milliseconds, but over a long trip, they add up.
My feet is my throttle response.
Yeah the car jerks around every mm of pedal travel.that's pretty cool, you are so coordinated that you can control your foot to fractions of a mm to ensure there are no spikes that lasts milliseconds.
a millisecond spike isn't going to cause the car to jerk. Not sure what you're basing your information on, other than an obtuse idea that says "if I can't feel the difference in acceleration, it's not accelerating". Not going to debate this any longer, have a good one.Yeah the car jerks around every mm of pedal travel.
mm=millimeter not (ms) millisecond. The accelerator pedal probably has about 60 to 75mm of travel.a millisecond spike isn't going to cause the car to jerk. Not sure what you're basing your information on, other than an obtuse idea that says "if I can't feel the difference in acceleration, it's not accelerating". Not going to debate this any longer, have a good one.
Both of those measurements apply. mm is movement of the pedal, and ms would be the length of the acceleration or deceleration spike.mm=millimeter not (ms) millisecond. The accelerator pedal probably has about 60 to 75mm of travel.
Thanks for playing, but no soup for you.
You're driving slower because you have to press harder on the accelerator for the same power, and driving slower is more efficient.
Yes. So anyone can drive slower with the normal setting also. We are just saying that driving at 60mph in chill or normal is going to have the same efficiency. Also accelerating slower with your feet in normal will be the same as stomping on it in chill.The only way to really clear this up is a long-term test of both settings, under conditions that are exceedingly hard to duplicate: real life.
In the meantime, this opinion sticks out for me:
