Has anyone come across the performance stats for Chill mode in Model 3 (LR in particular). I was just wondering what the 0-60 and 50-70 figures were like. Just trying to get an idea of what the actual impact is.
Similar to kickdown in an auto?I always found Chill mode perfect for everything, but wish it was a touch faster for overtaking on A roads. Standard mode for me is nuts and I hardly ever use it. I just wish there was a simple way to switch on the acceleration for an overtake and then revert to normal without using the touch screen.
I find the accelerator pedal works for that function.I always found Chill mode perfect for everything, but wish it was a touch faster for overtaking on A roads. Standard mode for me is nuts and I hardly ever use it. I just wish there was a simple way to switch on the acceleration for an overtake and then revert to normal without using the touch screen.
I have seen dyno graphs comparing chill mode in various model 3s. It essentially limits available power to roughly 200hp. Compare that to an SR+ having close to 300hp, a LR AWD having close to 400hp, a performance close to 500hp etc... It is quite limiting. All models seem limited to the same 200hp. I'm sure that'll make a 4000lbs car take 7-8 seconds to get to 60...
A major benefit of Chill is tyre life.Google is your friend here I think. However, there is no requirement to drive in chill mode (though it may help smooth things out for the first few drives of the car). Once your right foot is educated you can drive it like a hearse in a funeral cortege in whatever mode. You can accelerate as gradually as you want and you can slow down just as imperceptibly.
Sorry for not living up to your macho view of how fast people should drive. In Standard, if you press the pedal it accelerates hard. You have to be extremely light on your foot to avoid a jolt. This can be both annoying and also dangerous eg in a built up area. Chill mode is much smoother and safer. There is no need to be able to accelerate like the Model 3 (and all Teslas) do other than to try and impress people. All I said was a touch less 'chill' when overtaking would be handy.To be honest I'm still trying to process 'standard mode is nuts' - I found being gentle with the accelerator results in suitably restrained acceleration, though I suppose it depends on what car you had previously and what you have on your feet (diving boot perhaps).
Macho View ? If you are going to spout unadulterated nonsense I'd suggest you read the post correctly first.Sorry for not living up to your macho view of how fast people should drive. In Standard, if you press the pedal it accelerates hard. You have to be extremely light on your foot to avoid a jolt. This can be both annoying and also dangerous eg in a built up area. Chill mode is much smoother and safer. There is no need to be able to accelerate like the Model 3 (and all Teslas) do other than to try and impress people. All I said was a touch less 'chill' when overtaking would be handy.
