I'm getting an error when trying to install firmware on MCU1 from cid-updater recovery. Anyone know how to fix this?
cid-updater:40122: pending_command for retry: install http://192.168.90.101:80/2020.36.16-5-3e9e4e8dd2.mcu1 -o 0
cid-updater:40145: download status=complete
cid-updater:36361: flush_relays sid=204 filename=/dev/mmcblk0p1 abs_filename=/dev/mmcblk0p1
cid-updater:36399: relay status=flushed monitor_sid=204 monitor_name=downloading filename=/dev/mmcblk0p1
cid-updater:40149: complete_download status=flushed retval=0
cid-updater:19636: do_after sid=291 pending_command = stage install http://192.168.90.101:80/2020.36.16-5-3e9e4e8dd2.mcu1
cid-updater:32506: write_file status=error path= open=No such file or directory
cid-updater: 6393: dispatch_command status=error cmd=stage transition_state=fail state=ERROR
cid-updater: 6422: TIMER: do after: timerfd OD parent: 0 fd:03 dtr:-1 READY:i pending: stage install http://192.168.90.101:80/2020.36.16-5-3e9e4e8dd2.mcu1
cid-updater:40872: verify_offline_and_stage sid=291 retry command=install http://192.168.90.101:80/2020.36.16-5-3e9e4e8dd2.mcu1
cid-updater:41722: sid 291 has just asked to be kept awake
cid-updater:40920: signature status=starting
cid-updater:13764: send_gwcmd line=13998 sid=291 status=success latency=0.10 command=0xa retval=0a01
cid-updater:14509: verifysig status=in_progress fused=1
cid-updater:14563: verifysig elapsed=389 status=success key=prod chunked=false
cid-updater:14579: verifysig status=valid key=prod
cid-updater:40951: signature status=verified elapsed=389
cid-updater:14673: verifyversion status=error reason=offline_version_too_small offline=9 online=10
cid-updater:11007: mount_offline_package status=error reason=ratchet
cid-updater:40964: staging status=mount_error
cid-updater:17865: terminate_update from=verify_offline_and_stage at_line=41008 reason=package_signature_invalid sid=291 token=status=failure activity=signature invert_bank=0 reboot=0 early=1
cid-updater:12518: Writing sentinel /var/spool/cid-updater/factory_redeploy_active: false
cid-updater:12549: Wrote sentinel /var/spool/cid-updater/factory_redeploy_active.
cid-updater:12518: Writing sentinel /var/spool/cid-updater/terminated/terminated-: status=failure package_signature_invalid
cid-updater:12549: Wrote sentinel /var/spool/cid-updater/terminated/terminated-.
cid-updater:17787: enable_gateway_features status=error reason=swr
cid-updater:17791: enable_gateway_features status=error reason=drive
cid-updater:17661: kill_update_monitoring_sessions killing session 'keepawake' sid=36
cid-updater:17661: kill_update_monitoring_sessions killing session 'wifi-watcher' sid=205
cid-updater:45659: handle_sentinel_file status=sentinel_already_removed file=gostaged/gostaged_in_progress
cid-updater:17012: communicate_termination sid=291 status=starting token=status=failure activity=signature early=1
cid-updater:11794: warning: got 26 expirations (expected only one)
