To the Original Poster,
@skool:
I'm one of the resident EE's around here. Not an electrician, but close enough to see there from here.
I'm about to go all caps. Pay Attention!
POPPING A BREAKER IS A SIGN OF SOMETHING WRONG. IT MIGHT BE MINOR, BUT IT'S PROBABLY NOT. DO NOT CHARGE YOUR CAR WITH THAT WALL CONNECTOR UNTIL SOMEBODY COMPETENT HAS INSPECTED THE INSTALLATION AND MADE SURE THAT IT'S CORRECT. IF YOU DO NOT DO THIS,
YOU RUN THE REAL RISK OF A HOUSE FIRE. YOU MIGHT BE WILLING TO RISK THAT, BUT DO YOU WANT YOUR LOVED ONES HAVING TO EVACUATE ON A MOMENT'S NOTICE? DO NOT SCREW AROUND, GET THIS FIXED ASAP.
Use a Supercharger or public charging station in the interim.
Speaking as a troubleshooter, when one is faced with something like this, one needs to ask the question, "What could possibly be going wrong?" I presume that this is a new Model Y. There's
lots of possibilities, none of them fun:
- Bad breaker. It happens.
- Short in the car. It's new, stuff happens.
- Short in the wiring going to/in/around the Wall Connector. All it takes is something loose and touching something it shouldn't.
- Something broken in the new Wall Connector. Stuff happens.
And that's just off the top of my head.
And, now, in case you missed the lectures in High School Shop: Wires are generally made out of copper. Copper, like all metals, has resistance. Run current through a wire and it gets warmer: The equation is Power = Current*Current*Resistance_of_Wire. So long as: a) The load resistance is much greater than the wire resistance and b) the amount of current involved is less than the rated current for the wire, the most that this power dissipation does is get the wire somewhat warm. You can feel this effect when running a corded vacuum cleaner: The wire will be warmish after running the vacuum for a while.
Thing is, if one runs higher current than the rating for the wire, the wire involved, which is typically buried inside the walls of a house, will go past warm, past hot, and start charring the insulation. Left to its own devices, this can literally set the house on fire, and I Am Not Kidding.
A breaker/fuse is nominally sized so that these current levels are not reached: the breaker, which typically has an element that gets warm when current runs through it, much like the thermostat in one's house, will trip first, opening the circuit and Saving The Day.
The problem with this is that breakers are
not designed for an infinite number of trips. Breakers, after excessive use, have been known to fail. Sometimes they fail open. But sometimes they fail short. If one fails short, then Really Bad Things Happen, justifying the All Caps above.
Don't screw with this. Get it fixed, ASAP. And stop using the Wall Connector until somebody figures out what's wrong. It might be just a loose bolt, in which case no harm done. But it might be something a LOT more serious, like wires shorting to each other. You do not want to go there.
