Cleaning ink off tan leather
Discussion in 'Model S: Interior & Exterior' started by efusco, Aug 5, 2015.
  1. efusco
    efusco Moderator - Model S & X forums
    Nixa, Missouri, United States
    A valet driver at a recent hotel stay (with destination charging) apparently had an ink pen in his pocket which left a line on my seat. They've offered to cover removal if necessary, but id prefer to do it myself if I can do it well and inexpensively. Any advice on doing this? ImageUploadedByTapatalk1438804135.373814.jpg
  2. Brightonuk
    Brightonuk Member
    Plantation
  3. Jean-Claude
    Jean-Claude Local Vendor - Southeast
    Atlanta, GA.
  4. efusco
    Thanks, it's been 3-4 days already and those products have to be used in 3-5 days. I'll see if I can find something similar locally.
  5. Bulletproof
    Bulletproof Vendor
    Hawthorne, CA adjacent to the Supercharger & Desig
    You might want to try Goof-Off, since it's citrus-based, it shouldn't cause any harm to the leather itself.
    Also, I've had luck in the past with different solutions of alcohol and water.
  6. Jean-Claude
    Atlanta, GA.
    The urethane leather coating Teslas have is sensitive and should be cautiously approached with alcohol or any solvent. My advice would be to leave solvents and alcohol off the leather.
  7. Fezzik
    Fezzik P100D, M3LR
    Lincolnshire, IL
    I had this happen in my i35 grey leather seats. I used a steam cleaner and it came out with the nylon bristles of the steamer.
  8. tstafford
    tstafford Active Member
    Nashville, TN
    I'd try Mr. Clean Magic Eraser.
  9. sandpiper
    sandpiper Active Member
    Ontario, Canada
    I had the same thing happen on tan leather. I used rubbing alcohol. It worked perfectly.
  10. markb1
    markb1 Active Member
    San Diego, CA
    I'd be worried that would remove the protective coating, as well.
  11. tomas
    tomas Out of warranty...
    Chicago/Montecito
    There are a number of leather furniture cleaning products that are very effective. Give used to remove ink. Takes patience and multiple applications
  12. efusco
    Thanks all... Got an email from the valet service today (after completing an online survey from the hotel) that they've submitted a claim to their insurance company to cover the cost of professional removal. Rather than try rubbing alcohol or anything that might damage the leather I'll just get it done professionally and let the insurance cover it.
  13. Andyw2100
    Andyw2100 Well-Known Member
    Ithaca, NY
    #13 Andyw2100, Aug 6, 2015
    After they get the stain off, you may want to consider the CQuartz Leather for the future. I recently had my new Next Gen seats treated with it.
  14. artsci
    artsci Sponsor
    Timonium, Maryland
    I highly recommend leather cleaning products from the Leather Institute. Everything else I've used is garbage in comparison. So Iuse only their products, which include an ink and stain remover. Their cleaning wipes do a superb job for general maintenance.
  15. sandpiper
    Ontario, Canada
    I had some concern about that as well. I immediately dried it with a hair dryer and went at it with a leather conditioner. From what I can tell it seems 100%. But maybe it will degrade more quickly? Oh well. We shall see.
  16. mknox
    mknox Well-Known Member
    Toronto, ON
    Glad I wasn't aware of these concerns when I got a similar ink mark on my tan seats. I just went at it with a rough sponge (i.e. for cleaning dishes with caked on food) and some spray cleaner that actually had a bit of a bleach component. After I got the stain out I wiped it thoroughly with a cloth and clean water. That was a year ago and there is not a trace of the mark or my cleaning efforts to be seen.
  17. Jean-Claude
    Atlanta, GA.
    What can happen when cleaning modern automotive leather with an aggressive process is you end up compromising the urethane coating on the leather. That is not to say it will fail immediately or even in 2 years. It depends on how aggressive one gets. If the stain is just in the upper layer of the coating you may never have an issue as very little was affected. But there is no test to know exactly what you're working with and it's rolling the dice.
    OP, you're fortunate that they went ahead on the insurance claim. I would aim for a new seat cover.
  18. efusco
    Wow, really! I really don't want to go to that extent if it isn't necessary. Just don't know when I can get this thing in for repair/cleaning.
  19. Jean-Claude
    Atlanta, GA.
    All I can do is speak of what's know of the situation you face and what's ideal. By all means, exist with your Tesla as you need to. Sometimes we have to do what we have to do and I get that. But I think it's in your best interest to push for a new seat. That's a gnarly marking on tan colored leather...
  20. efusco
    Thanks again, I appreciate your input greatly and will certainly keep that in mind if it turns out the ink will not easily come off.
