Anybody have a easier, effective solution to clean window especially inside the car on the roof and windshield. What product is best. Windex does not work too well and kinda hard to wipe up and the back of the car.
I clean car windows for a living, and it's the number one question I get day after day...
here's the thing, the cleaner itself is the LEAST important aspect of getting crystal-clear streak-free windows every time.
I use OCNR because it's safe on everything on a car (and you!) and we already use it for so many other things while detailing.
Just use the two-rag method and work in small sections, especially if it's warm outside or you're in the direct sun.
I've tested countless glass ceramic coatings, both consumer grade and professional grade. My opinion is either go cheap with something like Rain-X and expect to reapply it often, or get the best which is Glassparency (only installed by professionals but comes with a 3 year warranty.)Wondering if there are any good coating for the windows exterior.
Anyone tried those cereamic coating for glass from amazon?
This is normal and will get better after you've warmed the glass a bit while driving.Rainx leaves the windshield foggy for half a second after the wiper goes over.
is that normal or am I putting on the rainx wrong?
Bosch Icon have been the best I've found. Not sure what else to try.What blade do you use?
I’m using Bosch icon, not good enough. Around freezing temp with wet snow, it ok but not perfect.
my model 3 has some haze. Maybes I need to do a deep clean. Autoglym glass polish didn’t do the trick. I’ll try alcohol later
