Kaivball,
As previously discussed, the following is a brief summary of the scientific basics of anthropogenic global warming (AGW) theory:
1. The laws of physics require that the long wavelength infrared heat energy emitted by the earth into space must equal the incoming visible and ultraviolet solar energy in order to avoid heating or cooling the earth over time. Over the past 11,000 years, with the exception of relatively minor local perturbations, or changes attributable to events such as global cooling from large discharges of volcanic aerosols, incoming and outgoing energy flows have been generally in balance and the climate has been relatively stable.
2. Greenhouse gases differ from the principal constituents of the atmosphere in that greenhouse gases are transparent to incoming solar radiation but are somewhat opaque to and trap the infrared heat energy that is emitted by the earth thereby insulating the planet and causing it to warm to restore the energy balance between incoming and outgoing energy.
3. Human activity, principally the combustion of fossil carbon in the form of coal, oil and natural gas to create CO2, is adding increasing volumes of greenhouse gases to the atmosphere. Current emissions exceed 30 billion tons per year.
4. About half of the greenhouse gases emitted as a result of human activity are retained in the atmosphere and are increasing the percentages of the greenhouse gases very substantially relative to the stable levels over the past millennia. CO2, has gone up by more than a third and continues to rise, and methane has increased by approximately 150 percent.
5. The greenhouse gases added to the atmosphere by human activity will remain in the atmosphere for decades and centuries, and block the escape of some heat energy thereby retaining such energy in the oceans, earth and lower atmosphere.
6. The average temperature on the earth will initially rise slowly over time due to the thermal lag associated with the heat storage capacities of the oceans but the rate of change is expected to increase over time as the levels of CO2 increase and due to a variety of positive feedback effects, increased water vapour in the atmosphere being principal among them.
If you are truly skeptical about AGW, I would welcome the opportunity to learn from you which element or elements of the above six part summary you believe is unproven, and the basis for your belief.
It would also be helpful if you could identify a national or international science academy (or another scientific body of comparable standing) which disputes the scientific consensus, or even a single, recognized, peer-reviewed, climate scientist who takes issue with the scientific consensus and refer us to a publication explaining the basis for his or her position. The articles you reference merely reflect an ongoing, meaningless PR exercise, and in the absence of substantive (i.e., peer reviewed) scientific support actually undercut the position and arguments that you are trying to advance.
