SO2 causes cooling; CO2 causes warming... that's how physics works. Most scientists recognized that CO2 was winning. Guess what happens if you pass laws to limit adding SO2 but lack the courage or intelligence to limit CO2...
Which fact do you think is untrue?
How can all be true but Global Warming false? If you deny physics.... you're not a skeptic, you're a denier... that's how english works...
- CO2 levels have risen ~40% since humanities fossil fuel addiction started
- The burning of Fools Fuel has emitted over twice as much CO2 as would be required for that rise (what hasn't collected in the atmosphere is acidifying the oceans)
- Doubling CO2 will cause a rise in temperature of >3C. The radiative properties of CO2 have been known and tested for >100 years...
I'm curious how deep this rabbit hole goes... do you think the Earth is flat? That water or fire are elements?
Thanks for the insulting and condescending reply, so typical of AGW alarmists these days.
Are you aware that millions of years ago CO2 was 10X higher than it is now, around 4,000ppm, and the earth did not burn up? As with most AGW theories your explanation is very simplistic and leaves out a lot, especially feedbacks.
