You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
The first time this fault occurred, it corrected itself. When it re-occurred, I booked my car in for a contactless service.
Concern: [SEE ATTACHED SESSION] Intermittent issue with climate control unavailable.
Investigation found that there is a fault with the Temperature Humidity Sensor (THS) ECU. Carried out replacement of the
sensor and confirmed the vehicle is now operating as designed.
Correction: General Diagnosis
Correction: Sensor - Relative Humidity and Temperature (Remove & Replace)
Parts Replaced or Added
MODEL 3 SERVICE KIT - HVAC SENSOR(1462944-00-A)
