Clipper Creek 100 amp and Model S
Discussion in 'North America' started by sp4rk, Nov 18, 2013.
  1. sp4rk
    sp4rk Banned
    Schaumburg, IL
    I should know this ...
    Working with an hotel and they are deciding whether to install a Clipper Creek 100A or an HPWC.
    The former is to be EV PC.
    CS-100 Charging Station with Pedestal
    With this High powered clipper creek, does it work the same way as our HPWC? As in, if you have dual chargers, you get 60 MPH refill?
  2. swaltner
    swaltner Active Member
    Kansas, USA
    Yes, a Model S with dual chargers would be able to pull 80 amps from the ClipperCreek CS-100 while using the J1772 adapter.
  3. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Yes, it works the same way.
    HPWC is cheaper, but you will only attract Teslas.
    CS-100 is more, but you will attract more EV drivers
    For a Hotel, speed is not the issue. 40 amps is plenty for overnight charging. The number of charging spaces available is more important.
  4. sp4rk
    sp4rk Banned
    Schaumburg, IL
    I realize speed is a non-issue, but when talking to them, I had in mind 2 or 3 Model S's doing a car trip in a group.
    As such, we'd all arrive at say 5, then take the HPWC in turns.
    And as EV's proliferate, I think high powered is better for same reason, no?
  5. Lloyd
    San Luis Obispo, CA
    If it were my hotel, I would put more 30 amp EVSE's and cover more guests that are going to be renting rooms overnight. Whoever plugs in will have a full charge the next morning. If a Tesla plugs into an HPWC and goes to bed, he's done charging quickly and nobody else can use it.
    High power is great if you can afford the numbers needed. I advocate them everywhere else except a hotel where you are staying overnight. Most Hotels do not want to be charging locations only. They put in the EVSE's to attract paying clients.
  6. Earthdog
    Earthdog Member
    United States
    sp4rk,
    Honestly the best solution if I were in your shoes would be a bank of 30amp or 48amp ClipperCreek or Eaton units. You will get more EV's to charge and a larger exposure or EV's. Since you are limited by total AMPS it really makes sense. I suggest you talk with the guys at Electric Vehicle Charging Stations | Atlanta GA Greg would be a great source of information.
  7. neroden
    neroden Model S Owner and Frustrated Tesla Fan
    Ithaca, NY, USA
    If you're amperage-limited at the breaker box, then given that your guests should be charging overnight, then yes, you can get by with less than 100 amps. The extra cost of higher-amp chargers is insignificant, so you should judge what to get by what your electrical feed can handle -- the extra cost of upgrading that can be quite large.
    The thing is, you really do NOT want to go as low as the very common 30 amps, because then some of your guests (the ones with 85kWh Model S) won't be able to get a full charge overnight. Get CS-60s (48 amps) at least.
  8. andrewket
    andrewket Well-Known Member
    Someone was advertising a dual-head unit. Supposedly if fed by one circuit it would load balance. That might be the ideal solution for hotel overnight charging from a cost/benefit and customer experience perspective.
  9. Earthdog
    Earthdog Member
    United States
    andrewket, the charge share solutions downgrade to 16amp from 30amp with two vehicle's there are new units coming but nothing in the remote to near solution.
    sp4k, the other thought here is the average stay at the hotel will be 8-11 hours so at a 25mph charge on a 30amp 200-260 miles gained in a Tesla. So going up to 48amps truly provides no benifit. Just my 2 cents.
  10. sp4rk
    sp4rk Banned
    Schaumburg, IL
    Thanks everyone.
    Now it's just the execution of the plan. It would be, IMO, wonderful to see ONE (1) hotel in my area put charging in.
  11. scott2613
    scott2613 Member
    Wisconsin
    I have an HPWC right next to a Clipper Creek CS-100. They both charge at 80A. Although the CS-100 is'nt that much more than Clipper Creeks lower amperage models, the installation cost can be much higher. Running four #2 wires and two #4 ground wires 275 feet at $2.60 and $1.25 per ft. respectively, 3" conduit and a separate 200A sub panel with 100A CB's was a lot more than the cost of the CS-100. Thousands more!
