Clunk in rear during initial acceleration
bmcnichols
12
12
Tampa Florida
I have a pronounced clunk noise when power is first applied to the rear drive train in both drive and reverse. It appears to be fine once under power and accelerates normally and I dont feel any abnormal vibration. I put the vehicle up on my lift today and thought I might find a bad rear bearing on one of the wheel hubs, but they both appear to be to tight when shaking the tires. There is some backlash on CV joints, but I wonder if that is normal play. I have approximately 45K miles and tires, brakes, wheels are all in good shape. Does anyone have any idea what I should try to investigate next?
X.l.r.8
1,425
905
Toronto/Miami
No it’s like a collar connecting the 2, like the torque tube to transmission connector in a Porsche 944. Only way to check is to drop the motor/transmission. Not the worst but far from ideal
glight2000
101
53
San Diego, CA
I had the clunk before and eventually tracked down the culprit: it was a loose object in the trunk rolling around when I accelerated. The object was actually a CAN Jr. :)
I put the CAN in a small cardboard box and cured the clink.
I hope you have the same “problem.”
Reactions: tvuolo and X.l.r.8
X.l.r.8
1,425
905
Toronto/Miami
That would be the best result ever.
hcsharp
3,370
1,337
Vermont
The best place I've found to store the CANs is between the seats. Pull it out by the draw string. That way you don't even have to open the trunk to start charging. If your legs are short and you have to adjust the seat too far forward then it may not work so well. Works best with the 2.5 seats but the 1.5 seats will also hold them.
Reactions: Mark77a
