Clunk noise from behind when accelerating/deaccelerating
R912
11
4
Denmark
Hi everybody!
I'm having trouble with locating a problem on my Roadster.
From the point of letting off and feeding the accelerator (and the other way around), there is a clunk noise from behind.
The car has done 153.000km/95.000miles and works perfect besides from this.
DeedWest
2008 VP & 2011 2.5 Sport
Feb 5, 2014
852
882
Dallas, TX
After owning a couple of different Roadsters over the years, I've always thought that noise to be standard for the drive unit when switching from normal to regenerative breaking. I definitely hear it more in my 2.0 than I did in my 2.5's (due to the increased sound proofing in the 2.5).
R912
11
4
Denmark
This is my second Roadster and my previous one did the same thing, so I thought it was just how they were built. But my brothers Roadster does not have this sound. I've checked with a third Roadster as well and it does not have this 'clunk'.
So I believe there must be a solution for this?
ML Auto
709
713
SW Florida
Check the rear tie rods for play. The car will seem to drift in one direction under acceleration, and the other during deceleration. When they get worn out they do tend to clunk.
Reactions: mpt
JayBee7
27
4
South Coast UK
It could be the coupling between the Motor and the Transmission, this is an internal connection so not visible, get your local Tesla Workshop to inspect.
I had the same noise on mine and it needed replacement, removal of the Motor was required
R912
11
4
Denmark
Thanks. Did this fix the problem?
R912
11
4
Denmark
Already done the tie rods as I had slack in them. I thought that the noise was coming from them as well, so I was a bit confused when I was done with the job.
