"Clunking sound" in reverse
Discussion in 'Model S: Driving Dynamics' started by tennisman, Feb 13, 2015.
  1. tennisman
    tennisman Member
    Westfield New Jersey
    after several days of having the car sit in the garage not being used, I've noticed that when I put the car in reverse to back out,the car seems to make a "clunking sound" and the shift to reverse in the transmission seems to not be "smooth". Has anybody experienced this - not sure if this is normal due to not using the car for several days.
  2. Chipper
    Chipper Active Member
    Chattanooga, TN
    What you are probably experiencing is totally normal. The brakes stick. Particularly when the car is put away wet. No harm is being done but it is unnerving the first couple of times it occurs.
  3. tennisman
    tennisman Member
    Thanks for the quick reply. You're right - it is a little bit unnerving when it happens, but glad it's normal.
  4. mknox
    mknox Well-Known Member
    Toronto, ON
    I'm not sure "normal" is the right word, but it certainly is very common. I don't think I've ever had a car where the brakes seize as much and as often as they do on my Model S.
