Clutch adds third of a second
vfx
14,790
40
CA CA
I had not heard this one before:
ELON MUSK: That actually is faster than any Aston Martin or any Ferrari currently in production. And that understates the acceleration of the car because a gasoline car 0 to 60 is measured from when the wheels start moving. The wheels only move after you've engaged the clutch. In our case there's no clutch. So if you were to measure a green flag to 60, we'd probably be apples to apples about a quarter second better than an equivalent gasoline car. So our 3.9 is probably like a gasoline car's 3.6.
from here:
Extended Interview: Tesla Motors Chairman Elon Musk | Online NewsHour | June 25, 2008 | PBS
stopcrazypp
9,862
4,797
from here:
When I heard that on the video I wondered what he meant when he said the Tesla was faster than any Aston or Ferrari. The F430 can get 0-60 in 3.5, the Enzo in 3.14. Evenwhen I heard it, without the exact numbers, I knew the Enzo & F430 was at least in the mid 3s.
I think what Musk means is if you start the time at when you start engaging the clutch, then a gasoline car that can get 0-60 in 3.6, when measured at the wheels, will probably take 3.9 seconds. Maybe he is talking about reaction time in drag racing, not that sure, since I'm not a drag racer.
Edit:
Reading more into it, in drag racing you can jump the gun a little by starting earlier than the green light so that the reaction time is minimized even with the clutch engaging. He does have a point about how 0-60s are measured from when the wheels start moving up to 60, but in racing there is the reaction time from the green flag to getting the car moving, which the clutchless Tesla probably minimizes. But since 0-60 is still traditionally measured from when the wheels start moving, the number should stay.
doug
Administrator / Head Moderator
Nov 28, 2006
16,852
967
SF Bay Area
He said something like "green flag to 60". So including reaction time, and time to work the peddles. I don't know if I believe him, though. Yes, if you were in the Tesla, you'd just floor the accelerator when you saw the flag. Some cars with electronic shifters are pretty fast, though. The Ferrari 430 Scuderia (shown in the recent Top Gear episode) supposedly shifts in 0.06 seconds, 0 to 60 in 3.5 s.
But more generally, we know Elon has a way of making statements while dropping important qualifiers. (Top gear acceleration comparison as an example.)
DaveD
EVs Kick Gas!
Aug 18, 2007
642
242
Redmond, WA
Is the F430 or Enzo currently in production? I ask because Mr. Musk was quoted using that qualifier in his claim.
vfx
14,790
40
CA CA
Yeah I think you guys nailed it. He is talking about the time between the green flag (or green light) to go and the wheels moving...
So I'm sitting at the Christmas tree waiting for the lights to begin I have my clutch is engaged, my car in gear and my revs are high. The green lamp innights and lift my clutch foot.
How is that different than stepping on the Tesla "torque pedal" ?
power
22
0
The only advantage that the "Torque pedal" would have, would be in the areas of modulating wheel spin. Reaction time would be no different.
light goes out, dump the clutch. :)
mk
Nov 22, 2008
197
0
You have to both release your clutch AND stomp your go pedal...with the Tesla it's just stomping the go pedal.
GSP
2,565
795
"So I'm sitting at the Christmas tree waiting for the lights to begin I have my clutch is engaged, my car in gear and my revs are high. The green lamp innights and lift my clutch foot.
How is that different than stepping on the Tesla "torque pedal" ?"
I think the only difference is more practice is needed to master a good launch. It takes several tries to find the correct engine speed to hold before side stepping the clutch. Too slow and the engine can bog, to fast and you'll get too much wheelspin. The Roadster's traction control will automatically generate just the right amount of wheelspin. All the driver has to do is floor the accelerator.
However there is reaction time from "green flag" to the driver flooring the accelerator on the Tesla. A skilled drag racer should be able to get the same reaction time in a manual or automatic ICE car, or in the Tesla. So no advantage to the Tesla on the dragstrip, but a nice advantage on the road.
GSP
TEG
Teslafanatic
Aug 20, 2006
21,717
8,682
Some track conditions and tires could dictate that some controlled amount of wheelspin would be helpful. Some highly trained, highly skilled professional racers may reject the idea that electronic traction control is appropriate for the track/strip.
SByer
'08 #383
Oct 23, 2007
1,068
3
Cupertino, CA
Yeah, but isn't controlled wheel spin really about keeping the engine in the lower chunky part of the torque band? Not necessary for an EV.
Or are you talking about getting the tires warmed up to bite?
TEG
Teslafanatic
Aug 20, 2006
21,717
8,682
Mostly the latter...
( The other thing is a cloud of tire smoke tends to be a crowd pleaser. )
GSP
2,565
795
I think you're correct that some slip between tire and track produces a faster launch. Traction control (often called "launch control" in this mode of operation) can be programed to provide the optimum amount of slip, and can do this better than even a skilled driver (and *way* better than a typical driver). This only gets better with an electric motor, which provides quicker and more precise torque control compared to an ICE.
As you say, some drivers may not accept this. I think F1 teams acknowledged the superiority of traction control by installing it on their cars. As a result, traction control was banned in an attempt to make the races more interesting.
power
22
0
EV vs piston engine is pretty close as far as torque available at power dump.
most engines are rev'ed to 3k and the clutch is dumped. gas pedal management as well as clutch release dictate the slip of the tires for optimal traction and acceleration. with an EV, there is only one pedal, as this same torque is available from a dead stop. only one pedal is needed to modulate the power application. this might be simplier, but in the skilled hands of a racer, not a huge advange.
mk
roopocket12
6
0
i agree tha to be able to achieve good acceleration, there should be good pedal management and clutch release. i believe this project is a good innovation to the electric vehicles considering that it is estimated to deliver the speed greater than ferrari and aston martin
