I’d be very interested in your process for DIY alignment.Gonna DIY this. Even considering DIY alignment but last time I did that I finished at 3 AM and seriously questioning my existence.
Alignment was perfect tho.
At the risk of derailing this thread... I used this system from this small company:I’d be very interested in your process for DIY alignment.
Just wondering what y’all paid to have coil overs installed + rear control arms / alignment. I’m in Seattle so any shop suggestions are also greatly appreciated. Thanks.
I was quoted $1000 to $1700 depending on the shop
How much does that cost, if you don't mind me asking?LOL - So i take my car to a well-known race alignment shop (West End Alignment, look at their Yelp score lol) and funny enough they do not use ANY lasers for the aligning process. It is 100% manual and old school style (chalk on the tires and manual gauges).
Granted they have the lift with pads that allow you to turn the tires, but still you don't need the fanciest equipment all the time!
All 4x corners should be about $500 without an alignment, hopefully a little less. Alignment really depends on where you go, but probably another $100 to $200 for a high-end place.
Man, that's gotta be a Tesla Tax.
Hmmm i have a terrible memory and it's cash only lol but pretty sure I last paid almost $200 for the alignment and about $350 for corner balance + alignment on a different visit, but i was the first Tesla they had worked on and had some additional adjustable arms that made it more time consuming for them to get dialed in.
What shop was this? Cheapest I have is $1600+tax for everything here in Seattle or 1470 in Portland including alignment.Specifically, it was $675 to install the coilovers, $135 for the front arms, $135 for the rear arms, $135 for changing out the sway bar links, and $275 for a track alignment (7.5 hours labor total @ $135/hour)
I DIY align my model 3, you really don't need anything fancy. Bare minimum required is two strings that are lined up parallel to the hubs and equally spaced apart, then two identical tape measures, and lastly a decent camber gauge.At the risk of derailing this thread... I used this system from this small company:
4-wheel Alignment System - Tenhulzen Automotive | WheelAlignmentTools.com
It was on my NB Miata. Double-wishbone suspension all around - 16 eccentric bolts in total. Car was on coilovers so it was even harder to access the bolts, since it had to be on the ground. Every time you change one setting, it throws other measurements off. Plus, you need to ensure 1) the suspension's settled if it's new and 2) some changes require you to roll the car back & forth so that your adjustment has "set." Started in the afternoon & wrapped up in the wee hours of the morning before having to get up @ 7 AM for an auto-x. When I took it out I was totally expecting it to drive sideways, but to my amazement it was absolutely effing perfect & I understood why I'd never been satisfied with an alignment from a shop - it takes time. Probably much less time with a $50,000 machine and a lift, but I guess still more than is "profitable." Maybe I've just never been to a decent shop... Swore I'd never do it again & sold the system.
But... I think the Tesla's suspension is far simpler, so I'm *considering* trying it again - but not with anything from that company. They make it seem far easier than it is, and their customer support seems to have taken a hit. Some of their other products don't even make sense to me - like their "2-Wheel Alignment System." How are two plates supposed to ensure the car's properly aligned when all you're doing is adjusting the wheels relative to each other & not the actual car? So unless I figure something out, I'll probably just end up taking it to a shop & bitching until it's perfect.
Back on track... I bought MPP coilovers & will definitely be installing them myself, but that's just me... it's way simpler than people realize. But this is coming from someone who's willing to spend 14 solid hours aligning a $3,000 car, so take that as you will.
I have nothing to compare to but this does look absolutely insane. $500 for brake lines? Lol. That's a 20-30 minute job.Hey guys. Is this insane or no? Granted I’m in Westchester NY, but still. If this is reasonable let me know. My other option is to drive to Long Island which will be a PITA.
You are pretty quick if you can lift the car, take off the wheels, replace 4 lines, fully bleed the system from 6 ports, and put it all back together in 30 minutes. But it's probably only 1.5 hours. The insane part is that the flush is not part of the brake lines$500 for brake lines? Lol. That's a 20-30 minute job.
You don't actually need the strings to be parallel to the car, just parallel to each other. You can back out the other error in math. Here's a great website that does all the math for you: DIY Alignment CalculatorBare minimum required is two strings that are lined up parallel to the hubs and equally spaced apart, then two identical tape measures, and lastly a decent camber gauge.
This was assuming the car was already on a lift for other work and there was another line item for brake flushing. Would be pretty dumb if they were putting the car all back together after every line item.You are pretty quick if you can lift the car, take off the wheels, replace 4 lines, fully bleed the system from 6 ports, and put it all back together in 30 minutes. But it's probably only 1.5 hours. The insane part is that the flush is not part of the brake lines
Wow, this is awesome. I've been looking for something like this.
Yes, but this is a problem when you quote work. The customer can come back and just say "OK, all I want is the brake lines" and then be annoyed when the price is not that because you had assumed it would already be on a lift with the wheels off and frunk out and you'd be charging separately for new brake fluid and flushing.This was assuming the car was already on a lift for other work and there was another line item for brake flushing. Would be pretty dumb if they were putting the car all back together after every line item.
