Preface 1: this is about aesthetics (wheel gap), not performance.
Preface 2: I'm measuring ride height using hub to fender measurements; I found out the hard way that tire pressure has a big effect on height measured from the floor! Also, at first I tried to use the jack points but found that they don't correspond to wheel gap very well.
The goal: have the same wheel gap left-to-right; Front Left and Front Right have the same gap, Rear Left and Rear Right have the same gap.
The problem: wheel gap is uneven, but on opposite corners of the car.
The Front Left and Rear Right are low; the Front Right and Rear Left are high. So let's say I want to raise the Rear Right in order to have the rears match. This has the effect of lowering the Front Left even more (it was already lower than the Front Right). If I raise the Front Left as well, then either the Front Right or Rear Left (or combo of both, which are already too high) come up so I have the same problem, just at a different height.
I don't have a clue how you might fix this, it seems that the car is just not square? I have the measurements within about 1/4"-3/8" so it's not a huge difference, but it's enough to be annoying.
I know many of you just corner-balance the car and be done; I'm curious, even in that case, have you found the wheel gap to be uneven in this way? I imagine it has to do with quality control when installing the fenders...
Thanks for looking.
Thanks for looking.
