Coincidence? I don't think so...
Discussion in 'Model S' started by tel, Aug 29, 2018.
  1. tel
    tel Member
    Northern CA
    3 year ownership with 58000 miles, just over the mileage limit for warranty, and the MCU dies. If I were the suspicious type, I'd assume that this was an evil manufacturing ploy, but I'll remain optimistic.
    Anyway, for those that have had this experience, how long can I expect repairs to take? My guess is that the limiting factor is the supply of available MCU's, and not the time it takes to install a new one.
  2. ucmndd
    ucmndd Active Member
    Service centers seem to be able to get MCUs relatively quickly these days. I don’t think you’ll have to wait very long.
  3. sandpiper
    sandpiper Active Member
    Ontario, Canada
    I've had two replaced under warranty. It was a few hours. There units seem to be a bit problematic.
  4. jorobsand
    jorobsand Member
    Charlotte, NC
    The service side of Tesla is not a profit center for the company (at least historically). They try to target service as a break-even. Of course this could have a lot to do with the many complaints and service not getting the attention from the company that it deserves, but it really explains the situation if there is little financial incentive to do so.
  5. tel
    tel Member
    Northern CA
    Truly - I was just joking about the planned obsolescence!
  6. timvracer
    timvracer Member
    Los Gatos, CA
    I don't believe this. $550 for service where they basically look at the car and replace my keyFob batteries? (... aaaaaand scratch my sunroof and have to replace it, but the replacement doesn't fit right so they have to order another one to replace THAT one... which I am still waiting for...)
    ok, maybe they are only breaking even... the hard way. :-(
  7. S4WRXTTCS
    S4WRXTTCS Active Member
    Snohomish, WA
    I wonder if you'll get an MCU2.
    I hope so. The MCU1 is known for killing itself.
  8. PhilDavid
    PhilDavid Active Member
    Philadelphia
    It's mostly due to the flash memory in the MCU wearing out -- right?
    The other common issue I know is the yellow banding issue where a liquid starts leaking from the screen. If you pay for a MCU, try your best to get MCU V2.0.
  9. UkrHog
    UkrHog Member
    Florida
    My MCU was just replaced under warranty on a 2017 Model S. After about 20k miles the yellow line showed up. After it was replaced Inasked if they were able to install the MCU 2 and one of the service managers said at this point they are no compatible. Disappointing. Hope this one lasts longer than 20k miles!
  10. PhilDavid
    Philadelphia
  11. Gizmotoy
    Gizmotoy Active Member
    Bay Area, CA
    Yeah, it'll need to be compatible at some point, if it isn't already. As far as I'm aware, NVidia doesn't make the chipsets in the original MCU anymore. Eventually they'll run out of stock of MCU1s for replacements.
  12. swegman
    swegman Active Member
    MCU2 uses a different wiring harness from the MCU1. Tesla has to make an adapter harness to install a MCU2 in a car that was originally built with an MCU1.
  13. TaoJones
    TaoJones Beyond Driven
    The Americas
    MCU in the first car failed at 63,000 miles the night before it was to be traded in at the factory for the current car.
    Had the SvC at the time reviewed the logs that they requested for review the week before when the MCU failed more briefly, they would have seen the alerts that would have prompted them to replace the 12V, thus avoiding the low voltage condition that contributed to the premature demise of the MCU.
    Instead, there was a fire drill to resurrect the MCU prior to driving 6 hours (7.5 hours due to the delay getting out of LA) to the factory (the mobile tech did what he could to no avail), and then to find a loaner for the drive. Non-AP, which was unfortunate, as the stalks are switched along with the obvious delta.
    Disappointing that there's no actual retrofit available yet for those that want one. The announcement was made months ago.
