Model S, Extended Range, born on 5/2020. Delivered 6/2020.
My Climate Control has stopped functioning properly. In addition, COLD air comes into the passenger footwell regardless of setting. If you turn off CC, there is a cold breeze blowing in around the feet of the passenger. This is after a recent visit and repair of HVAC sensor.
While driving last month, the heat would not regulate. With the temperature set to 73 or 77, the temperature went to 81 every time. When climate control was turned off, cold outside air immediately begins to circulate in the cabin (when “off” should stop all flow of air.) As I stated above, this is worse in the passenger side. When the cabin is at 81 and the outside air is blowing in at your feet at 45 degrees, this becomes intolerable.
I tracked the operation using the Tesla app during a drive from Birmingham to Tuscaloosa (45+ miles). Outside temp was in the mid 40s). I have screen captures from the app; temperature was 72 degrees in cabin, climate control off, time stamp 9:15. Turn climate control from off to on, temp set at 77. Temperature hits 81 degrees in 2 minutes (less than, and would still be rising but turned off as heat was oppressive in cabin), time stamp 9:17. Next, turn off Climate Control, time stamp 9:18. Cabin temperature drops rapidly from 81 to 72 (3 minutes), time stamp 9:21, because cold air is entering cabin at passenger side foot level (very cold air). With CC off, air inside the cabin should not be changing, nor should cold air be rushing in at footwell. There seems to be no regulation of temperature in the cabin (just goes to 81 degrees whether it is set at 77 or 73.
What should I do next? Last visit the evap temp sensor was replaced. This seemed to fix my AC issue, but this temp issue is intolerable. My wife won't ride with me without a blanket to cover her feet and legs.
I really hate the thought of driving the car to Nashville again, closest service, but I see no option.
