Cold near door
Discussion in 'Model S: User Interface' started by scot, Feb 11, 2016.
  1. scot
    scot Member
    Ashburn
    Anyone else notice that their heating is uneven? I get hot and cold spots around the drivers position, especially cold near the door at my left leg. There is plenty of hot air coming out of the system if I turn it up, but nothing on the left underside of the dash.
    Trying to figure out if this is "normal" or if i should add this to the list for service.
  2. AMPUP
    AMPUP Member
    Dunn Loring, VA
    Same as mine and with the sudden drop in temperatures in Virginia this week I can feel the cold air coming from the corners of the door, apparently a common problem that they do have fixes for. I guess Ill need to schedule but by the time i get in it will be late Spring :wink:. mine is a late 2013 delivered early 2014.
  3. AWDtsla
    AWDtsla Active Member
    NE
    If you have range mode on the car will not blow hot or hard enough to get all the coldspots.
  4. BoldSharpe
    BoldSharpe Member
    Wisconsin
    In the same vein, I noticed a lot of cold air coming through the interior door handle area. I hadn't noticed it previously but it has been in the single digits here lately.
    Perhaps the insulation wasn't installed properly? I'd mention it if you're bringing your car in for service anyway.
  5. trils0n
    trils0n 2013 P85
    SF Bay Area
    There are a number of air/heat leaks that can be addressed. The triangle window near the base of the A-pillar, the surrounding seals of the door, and the seals that keep air from entering through the exterior door handles. I recently had all 3 fixed at the service center and it has made a big difference in the cold spots and wind noise.
    Also, if you have an earlier car there is a service bulletin for an updated cover for the foot vents that improves air flow. Also had that applied to my car, as there was very little airflow to the driver foot area (much less than passenger side) and it helps a lot.
  6. Cyclone
    Cyclone Cyclonic Member ((.oO))
    Charlotte, NC
    I had the A-pillar window fixed in December, seals around the exterior door handle in January (which was then letting air into around the entire door trim panel and the interior handle), and the driver footwell in February. Each made a serious difference. The footwell change was significant. I can actually feel the air blowing down there now when I couldn't perceive anything when directing air to the floor and pumping the fan to 10 previously.
    The downside now is that I noticed that while its in the 30s outside and I have the car in the 70s, if I put it on recirc, it will blow cold air after 10 minutes. If I leave it on fresh air, it will keep blowing hot air (all with range mode off). This sucks though as the gas cars around me and all running rich because of the cold and its making for an unpleasant experience.
  7. miked112
    miked112 Member
    New York
    Happy to see this thread, I noticed it in the [email protected] NE cold this morning and just attributed it to the extreme weather - but the door handle in particular was ice cold. I also notice that when I'm preheating the car I can feel a little warm air coming from the exterior door handles. Glad there is a fix.
  8. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    My floor vents just plain suck. My feet are always cold. I took it in and they said it was "as designed". Well the design needs work.
  9. Cyclone
    Charlotte, NC
    Have you tried it with range mode off and fresh air manually selected? That was key for me. That said, cold for me is nothing compared to some northerners. It's only like 34*F at 10 pm now.
  10. CHG-ON
    Yes. Thanks. I actually never use range mode. Don't need it. I can set the car to all floor and I can clearly feel that perhaps 80% of the air is coming through the dash vents with barely a whisper of air coming out of the floor vents. I just don't know how they can say that it is working as designed. On one trip, I actually wore super-thick hiking socks, plush jammy bottoms (with little sail boats on them, of course-the looks at the SC were priceless) and slippers for the drive to stay warm! Everything from the waist up was fine.
    Oy.
  11. Cyclone
    Charlotte, NC
    I would have smiled, but only because I know the pain. Just checking though, fresh air mode, recirculate mode, or auto for that?
