Cold Weather Issues - Road Trip
Discussion in 'Model S: Battery & Charging' started by YYZ-IAD, Jan 21, 2019.
  1. YYZ-IAD
    YYZ-IAD Supporting Member
    Reston VA, Buffalo NY, Toronto ON
    #1 YYZ-IAD, Jan 21, 2019
    I've been on upstate NY road trip through recent cold snap (West Mass to Buffalo). Have encountered consistent issues that I assume are common with others in cold temps? Temps have generally been single digit F (-15 or so C)
    Charging has not been possible at overnight stops (hotels, relatives house, etc). In morn, I've headed for closest supercharger. Observations:
    1) Today at 1F, stayed in "starting to charge" for more than 10 minutes, so tried another unit. Same issue. Finally went to closest L2 charger - and got a 6kW indication. After 30 minutes, finally got 1kWh of charge. Went back to supercharger, and then it started to work - although at a very low rate - like 6 kW for 10 mins or so - before getting some improvement to 20kW.
    2) Yesterday, 4 degrees F, at another supercharger in morn, screen indicated "supercharging" but stayed at 0 kW for at least 10 mins. Switching units didn't help - so gave up and headed to next supercharger down the thruway.
    3) Appears that driving some distance warms up battery sufficiently - so that supercharging back to near normal rates.
    4) I am generally chill driver and summer consumption averages less than 300 Wh per mile. Yesterday on long trip on thruway, I consistently used over 450 Wh. Assume because: low temp of battery, "heavier" air from colder temps, softer tires, frozen snow on car had worse aerodynamics, more road friction from poor road conditions.
    On good news, Model S with Michelin X-ice winter tires is a mean machine blasting through all sorts of nasty road conditions. Never felt insecure with handling.
    A great education last days for someone 7 months into ownership and first real winter experience
    • Informative x 2
  2. animorph
    animorph Active Member
    Scottsdale, AZ
    Supercharging with a cold battery is very slow. It has to heat the battery up and then it can start charging. It will eventually start charging normally once the battery heats up if you stick with it. As you learned, Supercharge before you stop for the night, while the battery is still warm from driving.
    • Informative x 2
  3. HeinekenMS100D
    Boston
    A similar thing happened to me this past weekend in Grand Rapids, MI. Temp in the morning was about -2. It took about 10 minutes on supercharger before I finally saw a trickle of charge. Another Tesla owner was having the same issue so they called the Tesla service center which said the chargers must be done. After 20 minutes, started to get some decent charge going but was still pretty slow. I know it can be slow when cold but never actually seen miles and kw at zero while plugged into a supercharger. I now know to always try to charge when the battery is warm if it's going to be extremely cold and my car will be sitting out.
  4. Barry
    Barry Active Member
    Colorado
    While you may be anxious to get into a hotel room, do your charge in the evening BEFORE your final stop when the battery is still warm, rather than in the morning.
  5. tga
    tga Supporting Member
    New Hampshire
    Trying to supercharge a cold soaked battery is an exercise in futility. At first, the battery is too cold to take a high rate, even if it's nearly empty. The charge rate will gradually increase as the battery warms, maybe to 50kW-ish if you're lucky. By then, the battery is warm enough to take a fast charge, but too full to do so. So the charge rate starts to drop as the battery moves further along the taper.
    As @Barry said, charge before bed while the battery is still warm.
  6. YYZ-IAD
    All is your feedback is very clear and consistent: when in very cold temps, attempt to charge only after battery has been warmed through sufficient driving. Wasn't made known to me before - so I hope this thread has been helpful to others in northern climates who dont otherwise have access to overnight chargers.
    • Informative x 2
  7. Lasttoy
    Lasttoy Active Member
    St Augustine, Fl
    I hope you called 8777983752 to report your problem?
    Attached is a picture of your battery heat/cooling system.
    • Disagree x 3
  8. Lasttoy
    St Augustine, Fl
    This is what manual states.
    • Disagree x 2
  9. tga
    New Hampshire
    What "problem"? The behavior reported in the OP is standard "can't supercharge when cold" behavior, not a problem. No need to harass support...
    And yet the OP specifically said overnight charging was not available at the hotel... :rolleyes:
  10. YYZ-IAD
    Yep, on a long road trip - so only option was to supercharge on the fly. It would be nice someday if all hotels and all our relatives had adequate plug-ins - but not yet there in 2019. I'm optimistic this issue will get much better with time.
  11. tls
    tls Member
    New York, New York
    It's often possible -- and highly recommended -- to plug in to 120V overnight to keep the battery warm (I've heard conflicting opinions, but I always turn off range mode before doing this, to ensure the battery heaters run). Many, perhaps most hotel parking lots will have a 120V convenience outlet at the base of a lighting stanchion, etc. Be discreet (don't run an extension cord halfway across the lot) and limit amperage even below the 12A default so you don't blow any breakers; you'll sometimes lose a little charge to the battery heaters overnight in really cold weather but the battery will be warm and ready to quick-charge in the morning.
  12. dusdev
    dusdev Member
    Ontario
    I think this is a key message that needs to be communicated over and over again.
    Hopefully on your next road trip you can choose hotels with overnight charging options also. I think it's also worth mentioning to those hotels that do provide EV charging options that one of the reasons you choose them is because of the charging option.
