Tesla does say to not leave in in temperatures below -22° F for a day... I'm assuming that means that the battery gets that cold for a day. If it is plugged in and you charge slowly and then preheat.... the battery will prob stay fairly warm. 45 minutes to precondition. Scanmytesla shows that the battery seems to heat up into the high 50's but not much more. It seems like last winter I could precondition the battery all they way up to 70 degrees- being able to do so really increases the efficiency on medium to short drives.
Any chance you’re in Plattsburgh, NY? I used to live across the lake in Colchester, VT.
I’d be real surprised if the battery can hold 50 or 70 F at -20 while driving. On Saturday I couldn’t get the cabin to hold 70F with the heat running at full blast
In -13F weather. The upper cabin was fine, but my legs and feet were cold. I could feel the cold radiating from the doors and floor.
This isn’t an EV only thing. I’ve had ICE cars that I needed to put cardboard in front of the radiator on to get the cabin to stay at a reasonable temperature in sub zero temps, but that’s not been the case in 25+ years on an ICE car.
It *may* be possible to get the battery that warm during pre-conditioning, but I’d bet it won’t hold that temp while driving in -20F, and you’ll burn a lot of power to get it there in the first place, just to loose the added heat when you start driving. I bet you lose most of the battery precondition in the first 5 miles are these temperatures.
Both times I pre-conditioned in double digit sub zero weather last weekend I lost between 3-5% SOC while plugged in to a 7.6 KW outlet, and has been plugged in all day and night before.
My personal experience is double digit subzero weather is a very different experience with a Tesla Y than 30F, 20F, 10F, or 0F weather is.
On a side note, Tesla seat and steering wheel heaters are second to none. They are the most responsive I’ve ever experienced.
