Hey guys! As we all know, it's going to get REAL cold this upcoming weekend. Here in STL, we are supposed to get down to -3 with some -20 degree wind chill. This is my first winter owning a Tesla. Unfortunately, I don't have access to a garage.
Anything special I need to do to take care of my Model 3? I planned on just leaving it plugged into to the simple wall outlet while it sits outside. Is that the best best?
Any tips help. Thanks!
Yes, some pretty extreme temps are rolling across most of North America over the next few days.
Like you, my car sits out in the weather. No garage.
I'd recommend turning climate on 45 minutes to an hour before driving your car. That's to heat the battery pack.
Do any L2 charging immediately upon returning from a drive. Avoid using scheduled departure or scheduled charging which would allow the pack to get cold again.
Avoid Supercharging if at all possible. If you need to SC, first Navigate to your chosen Supercharger for a good 30 minutes or so so the pack can gets lots of heat in it.
Maybe bump the SOC you start with, before the worst weather rolls in, if that would help reduce the need to charge during the most extreme temps. The colder temps will significantly temper the cell stress that we normally worry about at higher SOC's.
Put your car in chill mode... and otherwise drive very gently until/unless you've driven a good long while. Avoid hard accelerations.
Reduce use of regen by using the regular brakes when you need to slow down or stop.
The objective in all these is to minimize current going into or coming out of the battery while the pack is very cold. Once you've been driving for a good while - maybe 30 minutes if you preconditioned, maybe an hour if you didn't - you can go back to driving normally.
