It stays in standard, but if the battery is cold, there will be a dashed yellow line indicating where regen ends. When very cold that line will be at zero.Is it my imagination or does regen go from standard to low if the car's not pre-heated?
In one of Tesla's rather boneheaded moves, when VERY cold, the dashed line will not appear, but regen will be completely disabled. It appears that the dash line only appears when regen is limited, but not fully disabled. And I'll also say that the difference between those 2 levels is mind boggling, even the tiniest amount of regen feels a lot different then when there's none at all!When very cold that line will be at zero.
There is a notification, but it's a once only thing that goes away quite quickly, I didn't notice a snowflake, I think that's only in the old 6.2 interface? Really I think they should also show the yellow dashed line extending all the way from zero. It's about a consistent UI.I think when it's at that stage, you will see a snowflake icon next to the battery, which will let you know that they are very cold, and regen will not be on. I also think you get a notification in the screen saying as much.
I still get the dashed line when fully disabled.In one of Tesla's rather boneheaded moves, when VERY cold, the dashed line will not appear, but regen will be completely disabled. It appears that the dash line only appears when regen is limited, but not fully disabled. And I'll also say that the difference between those 2 levels is mind boggling, even the tiniest amount of regen feels a lot different then when there's none at all!
Okay, I've learned to pre-condition my car now. Does Turing on the cabin temp also heat up the battery for regen?
Then your regen is only limited, not fully disabled.While mine shows up as an orange line on the power meter, .
I agree the change Tesla made with how they are displaying (and at times not displaying) the regen limit in Version 7.0 is severely lacking.
The regen limit has a direct impact on how we drive the car. If regen is limited, there should be a visual indication of this fact, preferably also providing us the ability to at least estimate the approximate amount of the regen limit, AT ALL TIMES. Tesla had this right in firmware versions before 7.0. But now in 7.0 in addition to the flakiness and inconsistency that green1 has reported, even when the system works as designed, and notifies the driver of a regen limit when the car starts, unless we keep the power meter on the screen, we do not see any indication that regen is limited while driving. And we do not see if and when the limit goes away. I do generally keep the power meter on the screen, but not everyone does. And for me, if the phone is in use, that temporarily takes the power meter's instrument cluster spot. If used in the other spot, the power meter's spot would be taken by the Nav directions. So even if we are making an effort to see the regen limit as best we can, there are times we are not able to.
Information as important as this, that impacts when we let off the accelerator, and when we need to step on the brake pedal needs to be displayed all the time. It's really as simple as that.
While mine shows up as an orange line on the power meter, even if it didn't it is immediately obvious when I lift off the accelerator.
Really didn't mean for this to turn into what it has. It's pretty obvious when regen isn't working as soon as you lift your foot. Heck, you probably know before you even get in the car.
I agree, I actually think they should have an option where it mimics regen using the brakes (optional!) to keep a consistent experience, but failing that, I want to be notified so that I at least know what to expect!If regen is limited/nonexistent when cold, okay, whatever. If the display of that fact has issues, they can be dealt with. What really disturbs me is I take my foot off the pedal and the car doesn't slow down. For a couple of months now (before it got cold outside) the car always began to slow when I took my foot off the pedal. The behavior shouldn't change like that. The car should slow just as it does at every other time, even if they can't reclaim the energy. I realize that would waste a bit of energy, and because of that maybe they'd want to make a setting for this, but to me it seems much more important that the driving behavior remain consistent.
keeping the power meter on the dash is my default setting. I know how much regen is available, and lift the accel pedal accordingly.
