Cold weather stopping all charging... Not sure how to deal with this.
Discussion in 'Model X' started by JakeTM, Feb 15, 2021.
  1. eml2
    eml2 Member
    Massachusetts
    Make sure Range Mode is OFF. When Range Mode is ON, it will not warm the battery.
  2. TSLA Pilot
    TSLA Pilot Active Member
    United States
    This!
    Call Tesla Service, or use the app, to mark the time and date, as this will help their remote diagnostic team fix the problem, and order parts, in advance of any mobile service visit(s).
  3. Rockster
    Rockster Active Member
    McKinney, TX
    #23 Rockster, Feb 18, 2021
    Resurrecting this thread to see if there are suggestions for our situation: Our S is in the driveway and is displaying a red charging ring. We can't get the car to release the charging cable.
    We've been subjected to rolling blackouts since Monday; however, our power is on now and has been since late last night. The charging ring is still displaying red and we still can't get the car to release the charging cable.
    We've cycled power in the car using the touchscreen and cycled power on the wall unit by tripping the breaker, to no avail.
    Any suggestions on what might be wrong and how we can get the car to let go of the charging cable and/or get happy again so that it actually starts charging?
  4. dmurphy
    dmurphy Woof.
    New Jersey - Morris County
    There's a manual release inside the trunk -- that'll get you unlatched.
    Now that said -- what charger are you using? Sometimes the Wall Connector needs a reset. There's a reset button on the side of the Wall Connector - hold it in for 5 seconds until it restarts and shows green lights. Try this AFTER you get the connector detached.
    If you're using a Mobile Connector, just unplug it from the wall, let it sit for 10 seconds and plug it back in.
    Good luck!!
  5. ModelNforNerd
    ModelNforNerd Active Member
    Ayer, MA
    Not in an older Model S......
  6. dmurphy
    dmurphy Woof.
    I'm almost positive it's been there since at least the AP1 models, which is @Rockster 's model ...
  7. Rockster
    McKinney, TX
    #27 Rockster, Feb 18, 2021
    Yes, this is a March 2015 build of a P85. Does it have the manual release?
    Time passes...
    No, mine is different. I have the same cover on the backside of the chargeport assembly but the switch shown in the video is not present.
    (My P85 is a unicorn. It was a Tesla rebuild, produced a few months after they officially discontinued the P85.)
    More time passes:
    I was able to solve the problem by resetting the wall connector. Even though I cycled power to the wall connector using the breaker, apparently actually using the "Reset" button resets it in a more complete way. This solved the problem and the car released the charging cable and now is charging properly after I plugged it in again.
  8. DaveRuns33
    DaveRuns33 New Member
    I'm just guessing here (as a new Tesla owner myself), but have you tried a different supercharger, or even a public charger? Maybe there's an issue with that particular charger.
  9. MorrisonHiker
    MorrisonHiker S 100D 2021.4.11
    Colorado
    Did you try pushing the button just to the left of the charge port?
  10. ModelNforNerd
    Ayer, MA
    also not on older Teslas. this one is only within the last year and a half or so.
  11. MorrisonHiker
    Colorado
    That's incorrect. It's been on all of our Model S and Model X since 2016. It dates back to when the auto-closing charge port was added to the P85D in late 2014.
    Here's a video of the P85D with the button in early 2015:
  12. dmurphy
    dmurphy Woof.
    First of all, that's really cool! A true unicorn indeed; if you have time, how did that come about?
    Secondly, even happier that the WC reset worked. They can be finicky at times... one of ours was NOT playing nice with our Model X for a little while -- that seems to have settled down with the 2020.48.x firmware, so I'm keeping a watchful eye on it.
    Very bizarre that you'd have the "escape hatch" in the trunk, but no lever on the backside of the charging port. That's a real mishmash of parts there!
  13. ModelNforNerd
    Ayer, MA
    My AP1 2016 S didn't have it. weird.
  14. MorrisonHiker
    Colorado
    If it had an auto-close charge port door, it had the button. You just probably didn't know it was a button as it looks like a rubber bumper for the door. They didn't actually enable the button functionality until the end of 2020...but it's been there over 6 years. When I read the release notes a few months back, I ran to the garage and confirmed it was actually a functional button. I then actually used it a couple weeks later since I couldn't unplug the Supercharger plug at a couple stops during a road trip. I've since used it at home a couple of times when the wall connector wouldn't disconnect.
  15. ModelNforNerd
    Ayer, MA
    I did the same, but by then I had a Raven X, so I was pretty sure it actually was a button. I use it all the time now. LOL
  16. Rockster
    McKinney, TX
    We bought an inventory P85 and later discovered that the car had been wrecked and repaired while it was a service loaner. Apparently, that information had been lost by the time the car was listed for inventory sale so the previous wreck wasn't disclosed to us when we bought it. We learned about this due to an unrelated incident when the service center damaged the paint while the car was in for routine service. When all this came to light, Tesla offered to replace the car with a brand new rebuild. As such, we have what is quite likely the last P85 made, built in March 2015. AP1 had come out by that time and Tesla kindly included AP in the build so it's one of the very few P85's with AP, too.
  17. dmurphy
    dmurphy Woof.
    That’s a heck of a long way to end up with a kickass car, but end up with it you did!! Glad to see they made it right.
