These are some awesome comparisons! I think you mentioned there’s a lot of customizations you can make with the xkglow but can you dim them at all? I kind of like the more subdued intensity of el wire but like some of the other things you can make the leds do that el can’t.
My white El looks a bit blue in pictures but less so in person for sure.BTW.....
If you look at those back doors.
That's ELwire ( WHITE ). It actually looks light blue because its really hard to make LED"s glow a perfect white.
View attachment 536679 View attachment 536680
Haha yea. Just plugged it in so probably hadn’t amped up yet. I live in an apartment so that’s what I’m working with but we’ve got a L2 charger in our garage as well if needed.On another note...are you charging on a 120V outlet?
Holy Smokes...its gonna take another 11+ hours to charge and you are at 248 miles?
lol
@Garlan Garner Specifically, what’s the best way to feed the el wire from the top gap and the Alcantara insert trim gap?@Garlan Garner do you have a picture of how you wired your lights on the door panel from inside the panel to the Alcantara insert?
I wired up the door but the only way to cleanly run the wire from inside the panel to the outside was through the top crease above the alacantara insert
Thats what I've done. Tapped into VC_Left near the driver footwell. I wanted it to be as OEM as possible and I can dim with the on screen brightness controlThose of you who have done the LED string lighting...is it possible to tap into the footwell lights for power so that the LED string lights dim when driving and turn off on their own when the car is parked?
Yea T-tapped and I have abstract ocean replacement lights in doors and footwell that draw more power than the originals but have not had any issue or cutouts.
note: I’m using el wire vs some others that are using leds which may draw more power
I used amazon because they come much quicker but you can get them cheaper on aliexpressThank you. You're one of the few knowledgeable people here. Link to the EL wire you used?
El wire- I like white because I think it looks more stock but that’s just me: https://www.amazon.com/dp/B07D7V14CQ?ref=ppx_pop_mob_ap_share
I used these T taps to connect them to Ambient lighting12v power https://www.amazon.com/dp/B072N7S3DL/ref=cm_sw_r_cp_api_i_Zv0XEbXMHFGFK
