Took out the airbag today to spray it to match the gray leather interior pieces. Cleaned with 70% isopropyl alcohol. Wiped down with 1:1 Purple Power dilution and lightly sanded with 1000 grit sandpaper. Then wiped down with alcohol once more. Sprayed four light coats with 10 minutes in between each coat. Extremely happy with the results and the color match is nearly perfect. Used Colorbond "Toyota Light Gray"
Just sharing my experience... hopefully it helps someone else
