Color me impressed with Tesla Service!
StellarRat
1,524
1,511
Pacific
Wow. I know people complain about Tesla Service, but I feel I got outstanding service from them. I took my car into the Portland OR Service Center last week.
More here: BMS_a035 error here and gone, what to do?
Anyway, they're done with car a day earlier than they estimated (impressive IMO.) Not only did they fix the error problem and buzzing sound/rattle under the steering wheel (for FREE no less.) They also rotated my tires, checked the tire pressure, did a four wheel alignment, filled up my washer fluid and verified they worked correctly, did two recall items, ball joint maint., and replaced my 12v battery all for FREE. I got way more than I asked for for free. I've NEVER experienced that level of service anywhere before.
RayK
2,295
2,300
San Jose, CA
Well, the tire pressure check I believe is a CA State mandate but yeah, I got the same great service (mobile) recently for the front control arm ball joint reseal. The first thing the tech did before he even unlocked the car was to attach the portable air compressor and pumped up the tires to 42-43psi and noted the tread depth of each. Topped off the windshield washer (which I filled two days before) and also checked my frunk latch per a service bulletin. He did the ball joints and then installed a set of cabin filters I already had on hand (thanks @TEMAI !) per my previous request.
Aug 7, 2020
827
1,746
Anyway, they're done with car a day earlier than they estimated (impressive IMO.) Not only did they fix the error problem and buzzing sound/rattle under the steering wheel (for FREE no less.) They also rotated my tires, checked the tire pressure, did a four wheel alignment, filled up my washer fluid and verified they worked correctly, did two recall items and replaced my 12v battery all for FREE. I got way more than I asked for for free. I've NEVER experienced that level of service anywhere before.
More likely they either forgot to charge you or someone else got the bill
  • Disagree
Reactions: KenC and StellarRat
