Ever wondered how Tesla combats the problem of LED refresh rates?
Looks like they individually address them and spin them around:
Many LED devices (alarm clock etc) does the same. that is to reduce power and heat from LED. It also reduces numbers of components needed to build complex display.
You can certainly dim LEDs without PWM. Just drop the voltage. PWM is typically used to dim LEDs because it's easy to control from a digital circuit. But if you just need a constant level, the easy thing to do is put a resister in series with the LED to drop the voltage. I suppose they would use PWM for power efficiency. (Though presumably it's possible to make LEDs that achieve the desired brightness at 100%.)
Yes but the resistor would burn a lot of power and get hot. Complete waste of energy and a potential failure mode if it gets too hot. PWM is really the sensible solution. It has very high efficiency because the driver transistor is either all the way on or all the way off, and this means it doesn't waste any power. It is also trivially easy to control the brightness by adjusting the duty cycle, no D/A converter required. Human eyes can't see the flicker. Low cost, efficient, flexible, reliable, effective. That's why everyone does it.
I will also point out that the MS DRLs are multiplexing between banks of LEDs as well as PWM dimming (when a turn signal is active). Multiplexing allows one driver to drive several banks of LEDs, further saving cost. White LEDs are so bright these days that they are not always needed to run at full brightness. This allows cost saving tricks such as multiplexing.
Often times multiplexing banks of LED's on a PWM circuit simply is cheaper, in that you can round-robin them such that they eye can't tell, but a single PWM circuit is handling all of them. Less components = less $$$.
In general, from my experience, LEDs are most efficient in the middle of their operating curve, they drop off at either end of the curve.
