Coming from an AMG CLS I find the air suspension ride a bit floaty.
Discussion in 'Model S: Driving Dynamics' started by hemants, Jan 1, 2015.
  1. hemants
    hemants Member
    toronto
    Not a fair comparison of course but is there any way to stiffen the suspension?
  2. svp6
    svp6 Member
    MN
    Of what car? S/P, +/D, air/coil, 19"/21"? You have to be more specific.
  3. hemants
    hemants Member
    toronto
    Model S Signature 85P on 19" Sotto Zero's.
    Air suspension
  4. doggshine
    doggshine Member
    I came from the cls amg as well.. the tesla can't compare because it is several hundred lbs heavier.
  5. tezzla
    tezzla Member
    SoCal
    I thought that when I changed from coil to air, I thought something was wrong with the car the first time I drove it home. I've found that when the suspension is set to LOW, it's not that bad (or I just got used to it). I don't feel the "floatyness" in the P85D though.
  6. ChadS
    ChadS Petroleum is for sissies
    It's hard to describe suspension feel, but I suspect the fact that you have a Sig may be a big part of the problem...early models were floaty all around. Later cars are much firmer.
    Service centers can partly upgrade a Sig suspension, but it's fairly pricey. I think some people identified some parts for do-it-yourselfers, though I didn't pay much attention. Maybe look for threads by lolachampcar.
  7. hemants
    hemants Member
    toronto
    Don't think it's a weight issue. 4300 lbs vs 4600. Not a huge difference -that's two passengers.
    - - - Updated - - -
    Yes, looks like early VINS had a squishyness (i've noticed the nose rises during hard acceleration). $5000 retrofit
    http://www.teslamotorsclub.com/showthread.php/29958-Early-VINs-removing-the-rear-squishiness-by-upgrading-suspension-components?highlight=suspension
