From what I've seen in analyzing heat records, charging doesn't start until the ess_min_temp reaches 6*C.Assuming ess_min_temp is the right field (for sleep record) and is in Celsius, the absolute minimum of all my sleep records is 0.96. I've had the car parked, unplugged, for 8 hours in -10C ... weird. 0.96 would indicate to me the ESS hasn't gone below freezing, so why was regen off?
Yes. I think the min temp for regen / charge is 6*CIn particular, for the day in question (12/6), the minimum for the entire day is 1.47. For the Drive1m records, I see a coolant_temp field, which was 0.5 when I started driving. Within 1 minute, it was 2.5. Regen didn't kick in (first 0x2c/Brake/RGbrk row) until 40 minutes later, with coolant_temp on the drive1m saying 6.5
Yes. 6*C What I think is more telling would be to plot the sleep temperatures across the 8 hour period when the outside temp was -10*C. This would give us some idea of how the battery mass responds to cold temp.The following day I started out with coolant at 1.5, regen kicked on 3 minute later at coolant at 6. And moving on to 12/8, start = 2.5, regen 18 minutes later at 6.5. Seems like 6 is the magic number... Do I have all this right? First time I've ever looked at logs and I'm just making educated guesses on the data I see here ...
I think that the coolant heater is a completely different heater to the cabin.
Yes it is. From what I can tell from the log heat and charge1m records, the heater in the ESS runs off of the battery directly. This makes sense because drawing current from the battery, heats the battery too.
I parsed a log from one owner during a pre-charge heating session. The current draws are as follows, I_ESS =-0.88A @ 400V, I_line = 0.2A @ 240V. So the total power used is 352W + 48W. My guess is that the ESS heater is about 300W and the power drawn from the line would increase with a battery that is more depleted.
I can definitely do that. There are two ESS temps in the sleep log -- min & max. and they vary between each other quite a bit. I can plot them both (there'll only be 8-10 points).Yes. 6*C What I think is more telling would be to plot the sleep temperatures across the 8 hour period when the outside temp was -10*C. This would give us some idea of how the battery mass responds to cold temp.
Plot of my ESS temps over the past 36 hours.
The spikes in temps are while the car is sitting, plugged in, and maintaining ESS temps (wow!).
The flatter lines are while I'm driving.
Those "spikes" look pretty normal to me. Thermostats typically work as a "bag-bang" controller with hysteresis. When the temperature drops to a certain point, the heat swiches on. The temperature increases and then the heater is switched off again. That cycle produces a sawtooth appearance to the temperature profile.
Yup! My wow is how often it's heated. It's 2kw of power while heating.
I'll calculate how much power is used to keep it warm later.
Bah, my VMS problem & reboot killed all heat logs from last night. I'll check again tonight, assuming it doesn't freak out again. Another cold night tonight (it's already 0F/-18C).
Keeping the battery heated for 14 hours was 40% of the energy used to charge it for 2 hours.
I detect a firmware feature request: option have the battery NOT heat until after the charge is completed. That way you can dial it in to charge in the wee hours, and have a nice toasty and freshly charged battery when you head out in the morning.
This doesn't make any sense, they only reason the battery is heated is to safely charge it. The battery must be above 32F to charge.
